The Very Best Amplifier I Have Ever Heard!!!!
I added a 30pf on each of my lateral mosfet outputs on another amp, as this was an update made to the later designs. I didn’t have any problems with that amp, and those parts were added with other changes, so I can’t tell if they contributed to any sonic improvements on their own,
My headphone amp, however, had been prone to a buzzing from some interference and the same parts, from gate to drain, has cleared it up. Silver mica, or polystyrene preferably.
I thought, I'll try to create it, but it's hard to do and very expensive and time-consuming, persevering.
Because before, I drew the pcb completely by hand, without the schematic diagram, so listing the components took a lot of time. I'll try
Hello friend!
You consider Goldmund. the best?
You have me as a client, if you're interested.
I'd like a couple of finished boards with components.
✅ Does anyone know what this top part does?
I hope it is as good as you're saying. I have a pair of Telos 2500 monoblocks in the making ;) I have also the digital input PCB dac with PCM1794 Dac chip. I used an Arduino processor and did the code myself.
SB
Reactions: 1 users
