*MTP3055VL MCE 6/9/97Hi all,
I'm building a spice model of the Reflektor D to help me understand the way it works while I'm waiting for the board of the group buy to arrive.
It's almost there but I can't find a model for the MTP3055VL. Does somebody have its spice mdoel or maybe a suggestion for a part that can reasonably well replace it in the model?
*Ref: Motorola TMOS Databook Q2/96
*60V 12A .12ohm Power MOSFET pkg:TO-220 2,1,3
.SUBCKT MTP3055VL 10 20 30
* TERMINALS: D G S
M1 1 2 3 3 DMOS L=1U W=1U
RD 10 1 56M
RS 40 3 4M
RG 20 2 40.6
CGS 2 3 389P
EGD 12 0 2 1 1
VFB 14 0 0
FFB 2 1 VFB 1
CGD 13 14 270P
R1 13 0 1
D1 12 13 DLIM
DDG 15 14 DCGD
R2 12 15 1
D2 15 0 DLIM
DSD 3 10 DSUB
LS 30 40 7.5N
.MODEL DMOS NMOS (LEVEL=3 VMAX=125K THETA=80M ETA=2M VTO=1.6 KP=18)
.MODEL DCGD D (CJO=270P VJ=0.6 M=0.68)
.MODEL DSUB D (IS=49.8N N=1.5 RS=31.7M BV=60 CJO=400P VJ=0.8 M=0.42 TT=55.7N)
.MODEL DLIM D (IS=100U)
.ENDS
Hello,
I managed to find 2sk184 JFETS at my local electronic shop. Their datasheet are exactly the same as the 2sk117, only that the sk184 are in a smaller package.
But there were only Y grades. Anyway, I bought them (15 only). I will build 2 pairs of BLB1.1 with them for my PCM56 future project.
Post1 sch still works.
For best performance the LOCATIONS of components needs to be considered.
See what you can find about monitoring the output voltage and how the lead outs of the monitoring circuit should be brought to the OUTPUT terminals of the regulator.
S0, S1, F0, F1 is typically used to differentiate between Force and Sense.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
