The simplistic Salas low voltage shunt regulator
iko
Ex-Moderator
Joined 2008
IMHO, even your first image has too much noise for this regulator; might be from your scope probes. Also, you have to be very careful what capacitors you use at Vout. You might want to try removing all those smd caps, and just use one larger size electrolytic, and test it first with a resistor load.
