where did you get that battery bastanken ? - i can't seem to find them in that size in europe anywhere...
I bought them from batteryspace.com
LiFePO4 26650 Battery:12.8V 3300 mAh (42Wh, 7A rate) w. PCB
I also bought a battery charger especially designed for these lifepo4 batteries
Smart Charger (1.5A) for 12.8 V LiFePO4 battery Pack (4 cells,15.2V cut-off) with 5.5mm x2.1mm Male Barrel plug-- CE / UL listed
I have been searhing for them in europe to but couldn't find them anywhere.
You'll need a proper LiFePO4 charge controller, which is designed to run from a solar panel. Charging a LiFePO4 battery without a controller will overcharge it, damaging the battery and possibly even causing a fire, and a "non-solar" charger might not work.
Something along these lines, I hope there's something a bit cheaper out there somewhere:
MPPT Solar Charge Controller for 12.8V LiFePO4 battery pack
Honestly, I'd go with SLA batteries. They're cheap, they're not *that* heavy, and they're fairly tolerant of overcharging - provided your solar panel isn't too big, you can pretty much just connect it to the SLA and not worry.
Okey, I thought a "normal" solar charge controller would work.
As you all noticed I'm not an expert of this.
Is it possible to connect 2 of these 10W, 12V solar panels (24 volt) to the charge controller you linked?
The reason I go with lifepo4 batteries and not SLA batteries is because they are forbidden in some festivals in sweden, so SLA is not an option for me.
One of those panels, or two of them in parallel, will work with that controller. They call it a "12V" panel, but it's maximum power point is actually 17V!Okey, I thought a "normal" solar charge controller would work.
4 Pcs Piezo Tweeters Replacement for Motorola KSN1001A
They write that thse are the exact similar Piezos as the original Saturnus used.. can any one confirm that? it seems wierd cause those are 4 for 18 dollars.. an the here Martin Sound its 1 for 23?
Those you are linking to are replacements tweeters, so they're only a replica of the original. The physical specifications may be the same, but i doubt that the sound quality is as good as the Motorola/CTS originals.
They might have similiar specifications (as in frequency range and sensitivity), but the sound is totally different. The Motorolas/CTS tweeters are simply just of much higher quality in all aspects.
okay.. im getting these parts on x-mas eve:
2x HP-10w
1x Amp6basic
2x QLM-1005 Piezos
and then two of these bassreflex tubes
If the 2 last parts arrent going to be that good then i'll just buy some others that are better.. its not that expensive..
I've read that the QLM-1005 will need some 33 or 47 ohm resistors with 3w .. could i use these then? and how many? RES .47 OHM 3W 5% METAL OXIDE - ERX-3SJR47
2x HP-10w
1x Amp6basic
2x QLM-1005 Piezos
One per piezo so 2 in total for the staggering amount of 1 dollar. Find out everything else you need to buy at Digikey so that you can buy it all at once.
i have no idea what i else has to buy :b hehe, but i might order some extra resistors
Saturnus, i cant remember if it was you who wrote something about at thing that would make the sound'siglna' from the ipod or PC louder and deeper.. It was a thing that you connect like this..
aux cabel from pc/ipod ect. into that little thing --> aux cable from the little thing to amp or headphone .. if you understand?
Btw, I bookmarked all the posts from this thread that I found useful in order to build a Boominator - thought I would share It with you guys.
And thanks to all the persons who participated in this thread, especially Saturnus
General design information
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-12.html#post1536139
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-20.html#post1679589
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-27.html#post1738505
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-77.html#post2366742
SketchUp file
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-78.html#post2367144
AMP related
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-75.html#post2312723
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-84.html#post2472847
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-209.html#post2646067
Resistor related
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-19.html#post1676491
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-37.html#post1862795
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-39.html#post1873631
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-69.html#post2281949
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-93.html#post2511682 including #922 and 923
Piezo related
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-43.html#post1885911
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-61.html#post2212458
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-61.html#post2213020
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-62.html#post2213747
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-77.html#post2365970
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-100.html#post2529783
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-116.html#post2550820 including #1152
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-151.html#post2572717
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-171.html#post2591419
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-185.html#post2608557
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-195.html#post2617406
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-204.html#post2636445
http://www.diyaudio.com/forums/clas...b-ultimate-party-machine-243.html#post2810510 (new)
http://www.diyaudio.com/forums/clas...b-ultimate-party-machine-243.html#post2810700 including #2430 and 2431 (new)
Batteries and power consumption
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-25.html#post1718421
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-66.html#post2247841
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-66.html#post2247898
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-84.html#post2472676
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-176.html#post2602727
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-224.html#post2676594
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-224.html#post2676823
http://www.diyaudio.com/forums/clas...b-ultimate-party-machine-243.html#post2810489 (new)
Solar panel related
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-78.html#post2380251
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-80.html#post2444529
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-85.html#post2477172
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-97.html#post2522253
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-97.html#post2522677
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-110.html#post2538482
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-117.html#post2552732
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-187.html#post2611683
Where to buy stuff
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-26.html#post1718431
Schematics and wiring
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-29.html#post1742547
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-87.html#post2486550
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-115.html#post2550803
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-130.html#post2560397
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-166.html#post2584008
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-168.html#post2585373 including #1675
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-179.html#post2606317
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-180.html#post2606453
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-188.html#post2612667
Center braces
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-22.html#post1680882
Cabinet related
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-21.html#post1679847
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-22.html#post1680903
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-51.html#post2102290
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-58.html#post2202014
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-86.html#post2480254 including #854, 855 and 856
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-93.html#post2514185 including #925
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-98.html#post2522699
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-99.html#post2522971 including #982, 983, 984, 985 and 986
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-106.html#post2538099
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-107.html#post2538184
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-108.html#post2538332
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-110.html#post2539098 including #1095, 1101 and 1105
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-111.html#post2539357
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-111.html#post2542222
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-112.html#post2543403 including #1118
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-114.html#post2546386
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-117.html#post2552911 including #1170
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-195.html#post2617532
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-202.html#post2631850
Misc Q&A's
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-95.html#post2517245 including #946
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-107.html#post2538256
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-117.html#post2552739 including #1168
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-189.html#post2613674 including #1885 and 1894
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-194.html#post2617343 including #1940
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-202.html#post2632278 including #2017, 2018, 2020, 2021 and 2022
Plywood and paint
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-190.html#post2613995 including #1897, 1898, 1899, 1900 and 1905
Sawing
http://www.diyaudio.com/forums/attachments/class-d/218626d1302873924-boominator-another-stab-ultimate-party-machine-boominator_cuts2.png
Cabinet finish (danish)
http://roskilde-open.dk/blog/sadan-samler-du-kabinet-ordentligt-og-laver-et-paent-finish
Tools
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-117.html#post2552726
Pictures
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-74.html#post2295893
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-75.html#post2325140
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-79.html#post2443791
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-114.html#post2550455
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-170.html#post2591182
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-187.html#post2611386
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-193.html#post2615520
http://s1080.photobucket.com/albums/j338/MarcusNordlander/boominator/?albumview=slideshow
http://www.minhembio.com/forum/index.php?showtopic=262694&st=0&gopid=2913948&#entry2913948
http://imageshack.us/g/593/89049866.jpg/
2011 Boominator meetup
http://roskilde-festival.dk/uk/tv/?mid=D8431830
Updated
Be aware of the dot before the number 47. The resistor you link to has a resistance of 0.47 ohm.
ooh, thanks! didn't see that the zero number must feel sad.. it never get usedBe aware of the dot before the number 47. The resistor you link to has a resistance of 0.47 ohm.
think i've found some? http://dk.farnell.com/yageo-phycomp/pnp3wvjt-73-47r/resistor-3w-5-47r/dp/1779314 ?? should they be in carbon or
think i've found some? YAGEO (PHYCOMP)|PNP3WVJT-73-47R|RESISTOR, 3W, 5%, 47R | Farnell Danmark ?? should they be in carbon or
Nope. Those are not metal film but wire wound. Same place same price
MULTICOMP|MOR03SJ0470A19|RESISTOR, 3W 5% 47R | Farnell Danmark
Saturnus, is it a big problem that im getting HP-10w in 8 ohm instead of 4ohm? .. no 4ohms on the market
You are supposed to get the 8 Ohm version of the HP-10W when using the AMP6 or equivalent.
thanks!You are supposed to get the 8 Ohm version of the HP-10W when using the AMP6 or equivalent.
- Class D
- The Boominator - another stab at the ultimate party machine
