THAM12 - a compact 12" TH
THAM 12 + 8x 3FE25
IMG_1181_cropped.jpg this one uses the faitalpro 12" and 8 3FE25 as line top.
working on a DSP version with 8 active channels (ADAU1452 + 4xTPA3116) for beam steering and shading, not yet ready ...
I have good luck with the roar layout and even catering to TS parameters and changing it slightly. (Longer and skinner) or (shorter and wider) is a function of Vas (and tge Qts fir Fs) or that approach seems to work for my drivers.. a bms 12 pair recently(friends build) . And splitting the initial path into a stepped can get some car audio drivers with Bl^2/re to work very good it seems. You can get really creative if a stub is positioned and tuned with conjunction of the system. (Rabbit hole to be honest).
Thanks for the info about the photo's ;)
Here ar some pics from the tham 12 with lavoce waf124.01.
