crown xls2000 photo
share some crwon xls2000 photo.
Little leisure in busy SHANGHAI show!
1.SMPS CLASS H PROAMP 3000W
2.SMPS CLASS D+CLASS B PROAMP 4000W
3.MULTICHANNEL PUBLIC ADDRESS AMP 5X50W
4.NEW PUBLIC ADDRESS AMP FROM BEHRINGER
5.New type Ipad stand and record system
6.Aluminum active amp panel
7.Aluminum active amp panel
8.Live show
9.Work hard!
10.Successors will unfailingly come forth
G36D amp going on
Many friends care our new G36D amp, First version have tested in last days, revised second version going on now, finished amp will come on soon.
added specs:
1.Multilayer PCB version , sound well.
2.Specific 100V or 220v auto switch.
3.dual TAS5630B chip inside.4ch or 2.1ch easy change
4.full functions remote control
5.ultra low EMI output inductor assembled, especially suit for radio signal amplify
attached first version main board and rear panel silk drawing here.
Good ideas or suggestions are welcome.
Compare with G33D, it is higher version .
1. all 24bit/192kHz audio stream,include USB source.
2. 2 tas5630B chip inside, ultra lower dcoffset and better sound than tas5630,
3.power out: 2X200W+1x200w or 4x200w ,
4. High-end Combo Sample Rate Converter SRC4392 support, Dynamic Range 144dB.
5.Excellent USB convertor apply.same USB convert chip as ASUS Xonar Essence One.support ASIO and WASAPI in windows system.
6.add LCD display unit, add rotary encoder volume adjustment and system control.
7.Remote controller
8. Sigma software full function support
9.auto switchable 110v or 220v switch SMPS.
10.Variable Fan cooling system inside, very low cooling noise when working
Link here to reference:
1.USB:
ASUS - Multimedia- ASUS Xonar Essence One
2. Asynchronous Sample Rate Converter :
Digital Audio Interface - Sample Rate Converter - SRC4392 - TI.com
3.TAS5630B:
Speaker Amplifier and Modulator - Mid/High-Power Amplifier - TAS5630B - TI.com
added specs:
New Genius member listed.G300DS is our latest Genius series AMP module, it is Hi-end products for digital source amplify .it accept two SPDIF source, two source convert by one switcher.Up to 192Khz /24bit sample rate supports.sound clear and powerful.
FEATURES:
1.TAS5630B chip full power design,high dynamic range.
2.auto reset SMPS protection OCP/UVP/OVP/OTP and AMP protection OCP/DCP/OTP.
3.Support variable fan cooling system.
4.Very low EMI design, suit for digital FM source.
SPECIFICATIONS:
1.Power out:2*150W/4Ω/0.5%THD+N(test one by one channel)
2.Input:2 coaxial SPDIF source (support switchable source convert)
3.SPDIF Sample Rate: 192KHz/24bit
4.Frequency response:20-20KHz +/-1dB
5.Loader:4Ω/8Ω
6.Ac Input:90-265VAC 50 OR 60Hz
7.Variable Fan :12VDC brushless fan
Hi Authlxl,
I probalbly have USB Audio out with my new setup (using Android Stick). Do you have an USB to Coaxial SPDIF board or box? Have seen pictures on your shop at Aliexperess but not any converter besides the digital transmitter.
I still plan to use the G300DS and build up a Power-Media-Player... ;-)
Cheers!
Andy
I tried a Sinewave Genius G300V21 recently, and found that with some ordinary speakers, the background noise (like hiss with attenuated HF content) was audible at the listening position. It was only after I switched to a pair of very low sensitivity speakers (82dB 1W/1m) that the noise was reduced to an "acceptable" level (still audible but barely perceptible at the listening position).
IMO, these amps still need additional work to improve noise filtering before they have a place in an audiophile-level system. Noise should not be audible at the listening position in a high-quality audio system.
Other impressions: Very well-controlled bass, even a slightly over-damped sound. These amps have very little sonic signature of their own through the midrange and treble, and certainly no 'sweeteners' or added warmth. If anything is wrong with the voicing of your speakers, you will hear it with this amp. Detail and texture are excellent.
I hope that Sinewave can address the noise problem with the G300V21 implementation of the TAS5630 soon, perhaps in a new revision of the PCB, because otherwise these would be excellent amps and a great value.
Ancillary equipment: Marantz CD5004 as transport, Musical Fidelity V-DAC, Mark Levinson No. 38 preamp. With my typical mid-1990s Hafler power amp, this system is silent, with no noise audible until about 1-2" from the speakers.
G300V21 AMP
Thank you for you reply here, maybe something error with your applying , pls try our finished G300 amp.we think you try our G300V21 module and without case.
if you heard hiss noise from speaker with our g300v21 board with normal speaker, pls check case shield, because signal input loader resister are 1Mohm, very high input impedance.we suggest you can assemble it in one case as shield.
G300V21 main specifications:
S/N > 100db
Dynamic Range>102dB
Noise voltage:28uVrms (A-weight,AES17filter)
Channel Separation: >84dB
Frequency Response: +/-0.5dB
if want to drive high sensitivity speaker, over 100db/m ,pls let us know, we have other board with very high S/N(>120dB).cost high price high.our customer use it to oil well logging, loader sensitivity>130dB.
S/N > 100db
Dynamic Range>102dB
G36V1.2 pass our test!
Finally we finish our G36v1.2 amp board test,sound excellent,works stable, very low temperature rise after 24hours burning-in .
First batch finished amp will finish this week.paste some main board pics here.
Hello,I tried a Sinewave Genius G300V21 recently, and found that with some ordinary speakers, the background noise (like hiss with attenuated HF content) was audible at the listening position. It was only after I switched to a pair of very low sensitivity speakers (82dB 1W/1m) that the noise was reduced to an "acceptable" level (still audible but barely perceptible at the listening position).
I bought two Sinewave G300V21 modules with the intention of using them to build active 2-way speakers. Like you, I'm pleased with their clean sound and controlled bass. I also experienced the same high noise-floor as you describe, but I figured it must be related to the source or a grounding issue since the noise disappears if the source is disconnected.
However, I have another problem with the G300V21 modules. They don't switch on every time power is connected. Sometimes I have to turn them on and off five or ten times before the green light comes on. Have you experienced this problem too? I have tried to get help from Sinewave, but despite being very help, language barriers are making the communication difficult.
Kind regards,
Soren
Hello,
Kind regards,
Soren
Thank you for your reply here. G300V21 turn off and on time a bit long, about 10-30s. because it have special circuit to protect the TAS5630 chip.soft on and fast repeat reject .
we will upgrade this performance in later version, we will make G300V30 version, we will apply special SMPS and make G300V30 as ultra lower interference with radio .it is bigger upgrade.
sorry for the inconvenient!
plz give us more good suggestion about it, we are plan to make two type,one stereo output(2BTL) and the other mono (PBTL).
This is exciting news. Please take a look at the products being sold by ICEPower A/S, which also integrate a switch mode power supply on the same circuit board as the amplifier stage. The ICEPower modules are very well regarded, and their modules have a very low noise floor. If you could investigate these modules and achieve similar low noise levels with your new G300V30, it would be a great value in Class-D/switch-mode amp modules, because the sound quality was already excellent when I tested the G300V21 (even though it was slightly different from the ICEPower module). The similar module to your G300V21 is the ICEPower 125ASX2 module.
I'm interested in continuing to investigate these affordably-priced modules, and I'll probably try to get one of these G300V30 modules once they are available.
Thank you for your reply, we will finish this task quickly!we will paste pics here when finish.
Thanks again!
...Like you, I'm pleased with their clean sound and controlled bass. I also experienced the same high noise-floor as you describe, but I figured it must be related to the source or a grounding issue since the noise disappears if the source is disconnected.
Kind regards,
Soren
Hello Soren,
Just to follow up on this, I connected a HF compression driver to the output of one channel of my G300V21 sample and was able to hear the previously noted background hiss clearly, with no source connected. The hiss seemed to be greater at low volume levels, and decreased through the middle of the volume range but near the upper end of the volume scale the noise increased again. This was independent of having a source connected to the inputs.
Hopefully the new revision of the G300 board will be quieter, and I appreciate Sinewave's quick attention to our comments. Maybe some changes to the output filtering of the power supply stage will be enough to clean up the amp's sound. Looking through the other modules and boards in this thread, it looks like there are some very smart and ambitious designs in here. I also particularly like the black PCBs. The products are also very imaginative yet practical - I can think of plenty of applications for the Genius G33D.
Hello! Taterworks, our G33D amp update nearly,additional functions list below:Hello Soren,
1.headphone plug insert mute main speaker output function, it is DSP function.
2.revised rear panel as 2mm ,so user can connector wire to 5way binding connector easier .
3.revised PCB route to G33DV3 version, higher S/N.
latest batch of G33D amp will finish 10-15days, we are appreciated for our customers give us so good suggestions in developing procedure.
we think G33D is realistic type , and G36D is Hi-End type.
G36D AMP FINISHED!
We take some G36D photo from our line today, share here.Assembling silver panel now,black panel have not finished now.
G36AMP FEATURES
Features:
1. Optical /Coaxial/USB/Analog 4source switchable .
2. High power version :4x200w/4ohm 4CH mode or 2x200W+2x200w(sub) 2.1CH mode.
3. LCD display system and only one rotary encoder control system.
4. all 24bit 192kHz Hi-End system. professional audio DSP core inside.
5. Ture USB 2.0 interface , 24bit/192kHz in win7 and OS system.
6. Dual TAS5630B PHD chip inside, 4ch mode or 2.1 mode software control.
7. Multilayer PCB design, high power density and very well EMI
8. Auto Fan speed control system, no fan cooling noise at standby status.
9. High efficiency system ,very low temperature rise after 24hours continue working.
10. High power SMPS support, global AC supply.110v or 230v auto switch.
11. Perfect remote control function, concise remote controller with infrared ray.
12. Ultra low EMI design and parts ,suit for Radio signal amplify.
13. Hi-end Headphone amplify system, Headphone plug insert main out mute function.
14. At 2.1 CH mode ,subwoofer channel cut off frequency and gain adjust alone.
15. SPDIF out function, suit for record and cascade connection.
Features:
Thanks for your comments. Have you had any problems with the G300 not always switching on when power is connected? I have two boards and they both have this problem. I've tried the amps in different homes, even the in two different countries, and the problem persists.Hello Soren,
we have answered your questions here.
New versions G300V30 will finish next week,
Main Features:
1.Power out:
2x240Wrms/4ohm(1%THD+N)
2x125Wrms/80hm(1%THD+N)
2.High Power Resonant SMPS and fixed 50V DC/12A support.
3.Four layer PCB, well routing and better EMI .
4.Fast on and off .
5.Special PWM out good indicator circuit.
6.Variable Fan cooling system, 12V DC brushless fan necessary.
7.110V or 230Vac power supply.
8.Auxiliary Power out: +/-15v @200mA and +5V@500mA
9.High level active MUTE function.
10. Boot noise suppression and without output relay soft start circuit
I saw your answer, but it didn't make much sense to me. The problem is not related to a "slow" start. If I leave the power on for 30 seconds or more the modules still don't turn on. I have to try turning them on/off 5-10 times before the green light comes on. It seems strange that I have two boards with this same issue. That's why I asked Taterworks if he had experienced the same problem with his G300 module.we have answered your questions here.
we think your G300v21 have problems or your ac supply not good, pls send mail to us to repair or replace.Thanks!
All the products pass our AC power supply adaptability test before sending.
X2000D professional class D AMP testing now!
Some customer asked for finished 1000W-2500W professional class D amplifier ,we developed one new series class D amp , now in testing. we have 2000DU or 1000DU modules have approximate functions, but it is mono type and narrow range AC power supply.
we found crown XLS Drivecore series have similar functions,but it is narrow range AC power supply too, it is complex for our customers to apply it in different country.
so we decide develop one new class D amp , testing now.
Main Features :
1. Independent excitation 300kHz osc signal
2.Output MOSFET body diode blocking circuit
3.High efficiency interleaved PFC stage and high efficiency resonant half bridge SMPS.
4.High speed DSP processing system, process audio signal and all protect issue.
5.Multi-layer PCB, works stable.
6.All in one board design.
Main Specifications:
1. 1000W/2000W/2400W@4ohm(1%THD+N)
2. 100Vac-265Vac 50 or 60Hz
3. Sensitivity: 0dBV
4. Frequency Response: 20-20KHz +/-0.5dB
5. Damp Factor:>200
6. Balance input
7. 2 single end or 1BTL mode
8. Variable fan cooling system.
9. S/N:>100dB
Main Features :
5. Damp Factor:>200
6. Balance input
9. S/N:>100dB
My sample took only about 5 seconds to click on, which seems like an OK duration for making sure that the power supply is stable. 120V here.
- Vendor's Bazaar
- Tas5630+smps+aluminum case finished!new year coming!
