Super Regulator, collecting the facts
janneman said:
I am sure that is the way to go. Not only for regulators, also in other audio-related applications. For one thing, you get low THD not just at 1kHz but out to 100kHz.
However, I would hesitate to give the details about this next revolution in audio to Per.
I'm a little bit skeptic about using 3 kV/us devices in our world of RFI but otherwise there are some very good CFB and pseudo-CFB opamps out there. A minor disadvantage would be (maybe) that many of them is optimized for 5 volts or +- 5 volts.
Re: Audio Revolution?
Elso Kwak said:
Faster is better? I doubt it! Your QSXPS on your site is in fact a Jung like regulator with a Darlington pass transistor and a LM431 as the reference.
If you check very closely it is not a Jung regulator, more like Sulzer, but the regulator was designed many years ago and the "invention" is mine but more people than I have got the same idea. A typcial case of parallel thinking. Not a very unique idea I'll guess.
Elso, I share your concerns about faster = better
faster = more potential problems also, no real quality enhancment
AX tech editor
Joined 2002
Elso Kwak said:
Hi Jan and John,
Faster is better? I doubt it! But the current trend is like that. I tried some pretty fast opamps like AD817. Not my piece of cake.
Per-Anders what are the real motives to start this thread? Collecting facts? Then you have only to copy articles from the net and the Audio Amateur journal. Your QSXPS on your site is in fact a Jung like regulator with a Darlington pass transistor and a LM431 as the reference.
Elso,
I don't consider the AD817 as a large step forward. No, what I mean is those opamps with essentially flat open loop gain up to 100kHz or so. They have negligeable phase shift up to 50kHz or so, so compensation can be done way outside the audio range. Then you get 20kHz performance which you have now up to 1kHz. And no, I'm not going to give you any part numbers. I need some job security...
Have a nice weekend,
Jan Didden
Re: Re: Audio Revolution?
janneman said:
Elso,
Jan Didden
Sorry Jan, I don't understand your post. Except for the AD811 current feedback opamp, the AD817 is the fastest opamp I have in house.
Open loop gain is flat to about 10k. You want still faster??? :confused: You believe you will get this working without oscillation? Chapeau.
Have a nice weekend too;)
You have to do it to find out
Peranders,
Discussions here about the best etc. are rarely ever useful, different people have different opinions based on their own experiences. It matters not one jot how much experience they have as it all has a context and underlying agenda.
As one designer* used to say: -
"A system is only as good as it's weakest part"
It doesn't matter how good the best bit is, the worst bit will be the dominant factor. In my experience the process of audio design is about dealing with those 'worst' bits and then finding another layer of them underneath. As Matt Jonhson of The The sang "...and the whole godamn thing starts all over again".
With the greatest of respect the reason you cannot hear those things you mention is because of your worst bits, and only you can locate and deal with them.
I promise you you will find it enlightening, challenging and that you are unlikely to want to give away the resulting information on a forum, 'cos it will be bloody hard work for you!
Andy.
*Julian Vereker MBE
I think indeed that some discussions can bring up facts, like the one we had about symmetrical vs. unsymmetrical amps (thanks andy_c)! The conclusion this time was that distortion spectra looked different but we couldn't agree which one was the best :no:
I will probably give away everything (except for one thing) in the future like I do now. I'll see no reason why I would change my mind.
Enough Fredjacking :)
and let's get back to the issue.
Thanks to a forum member I have now got hold of and read
the TAA article series on the superregulator (and other
regulators). It is very interesting reading and it seems basically
all questions asked so far in this thread were already answered
there. However, I do wonder about one thing. These articles
still use the version with AD797/AD848 and with the opamp
powered from the raw DC side. I understand that more
recent versions use AD825 as the preferred op amp and also
powers it from the regulated side. In fact, I already before had
such a schematic, which seems to be copied from a printed article.
I thus conclude there must be at least one more recent article
than those I have (parts 1 - 4). If this is a continuation of the
article series in TAA I don't know. I would thus appreciate info on
this/these article(s), and would also, if you excuse my boldness, appreciate if someone could mail it/them to me.
Thanks in advance
Thanks, that EDn article was new to me. However, I am still
wondering about the origin of the following schematic
Christer, you didn't read the third post from top?
I had the EDN link and read it and the reason why I started this huge thread was that I wondered of a couple of things which the article didn't reveal.
I wonder also where the picture comes from. I've an another picture which is more or less identical but it seems to it comes from a datasheet or application note.
Hm, probably read and forgot. The thread has become somewhat
lengthy. :)
I might be wrong, but I strongly suspect the picture I posted
above is from some magazine article. Note also that it clearly
notes certain modifications wrt. to some earlier version, which
seems to indicate it is a follow up article to earlier publication.
janneman said:
This must be from a follow-up to the Audio-Amateur article series. The schematic is for a 5V version done by Walt Jung. I recognise the terminology for the terminal names as the ones I initially used in the AA article, part 3.
Jan Didden
Eh, why then does it say +14V on the output. :scratch: :)
Anyway, I would be interested in this or any other article
discussing the changes of opamp and opamp supply.
Fred Tracking ...... and not Fred Jacking
'Another excellent resource for the Jung regulator is ALW's site here:"
http://www.alw.audio.dsl.pipex.com/jung_schematic.htm
This is Andy's updated version and not the Jung regulator.
How is Peranders going to get his all in one regulator PCB done if you guys keep confusing him with all these versions? Just don't show him the version with all FETs instead of BJTs. That is the newest one.
