Subwoofers for Beach Radio...
hmmm and with an inductor used that dip flattens out a lot, so it is actually a bigger difference in spl between the two at 90hz.
i'm leaning towards the ss15 currently, thanks for the comparisons!
The SS15 with a 3015LF will give more > 50 Hz bass than most anything in the size and weight range.
A pair of Lab 12" speakers in a smaller BR cabinet (22.5 x 22.5 x 26.5 inch exterior, 36 Fb, 32 F3) will put out a lot more level below 50 Hz, but will weigh more.
For the type of music you want to bang out, a subjective choice. The 2x12" Lab is almost perfectly flat from 36 Hz to around 120 Hz, with a 2 dB "lift" in the 40 Hz range.
And just a pair of those drivers will weigh 50lbs, i was really fond of the 50lb total weight for the ss15...
That is correct, as I mentioned before. The cabinet will weigh 100 pounds made from decent 3/4" birch, but is slightly smaller than the SS15.
There may be some neo drivers that have similar specs as Lab 12" to keep the weight down, but would probably cost more.
When I designed the ported Lab 12, it was after using horn loaded subs that had plenty of upper bass, but lacked below 50 Hz. I was tired of lugging in four big cabinets to get LF extension, the ported cabinet goes low with just one.
Jbell's SSTH is a great cabinet for upper bass, but does little in the octave below 50 Hz . If you are willing to trade upper bass level for more lower frequency level, the WS 2x12" is for you.
It is a simple build, two front loaded cones in a ported box. Nothing special, other than the amount of LF from a relatively small box, and very flat frequency response. I did not bother with PPSL, the distortion specs are below 10% at full power sine wave testing.
Details are here:
FREE SUB PLAN: Dual Lab12 (Front Loaded) by Welter Systems
Let me remind you of your own statements before you go crazy ;)
Right now its up in the air. all i know is that i have 500 RMS and want the loudest sub setup possible...BUT...portability is a big issue. it can be a decent size, i will use 1/2" plywood to keep the weight down.
one last thing, price. i'm not made of $$ (hence some of the driver choices, some stuff was left over, some was purchased cheap
) i would like to keep this thing down in cost. i was thinking about $150-200 max for drivers.
So i'm going to say that 45hz is a necessary bottom end for the sub. if that's all the driver responds to then thats fine
i'm using 12v JL audio amps to power this, off of a battery in conjunction with a home made 12v generator (alternator connected to a small gas motor) the generator and small battery will be replacing the deka 100 and 50 lb batteries previously used. so i have the amps already and power is taken care of.
I know I remember all of that. That's why I am still leaning towards the ss15.
It's in the price range I wanted (probably $230 all said and done)
It's only 50lbs. ThAts a breeze for me And one friend. Even me myself (I'm 240lbs lol)
It will do 45hz with some authority. Maybe not 40, but 45 looks good from the sim. That's right around what I was looking for.
Lighter with thinner ply than the design calls for, and lighter speakers (more $) than the original units. So basically it would cost almost $400 (twice of what i was looking to spend)
I do appreciate the suggestion! i still am leaning towards the ss15.
I have a JL 500/1 to power this.
Now, I’m not saying build this or that, it’s all your choice. All I’m saying is the THAM gives more low-end that can be essential for dance music. The real question for you is what do you need most:
1.) Low extension at cost of total SPL
2.) Highest SPL at cost of low extension
Another thing you need to consider, if you going to load these cabs with 250 watts you don’t need expensive drivers with high Xmax. So if you want to make a economic decision you shouldn’t pay for ‘extra’ excursion you are never going to use :scratch2:
Your worry about the ¾ suggestion for the THAM, please do read the thread of Jbells carefully. You will understand why Jbell isn’t worried to use thinner sheets. The same counts for the THAM. The ¾ suggestion was based on the maximum refinements for lowest THD in a THAM. Your goal is more like Jbell’s; Practical! And that few extra dB’s of THD don’t make up for that extra weight in his view…
