stereo SE kt88 build ... abdellah diyaudioprojects design
I'm sure others will chime in here but I can make a couple of comments:)
Your layout is ok but you want your laminations on the choke and the power transformer to be at right angles to each other to minimize hum. Personally, I would put the input jacks at the front of the chassis close to the first stage to avoid running the signal cabling through the power supply. I have built a few amps and preamps and the one thing I HATE is hum. Keep signal cabling short and shielded(shield tied to ground at source end to avoid ground loops). I know this isn't always as aesthetically pleasing as jacks on the back of the chassis but you are after great sound, right?:D I assume you will be using AC for the filaments; keep your filaments supply wires twisted and as compact as possible. You can even shield them but it is typically not necessary if you are neat. Heat shouldn't be an issue if your chassis is properly ventilated. I usually drill vent holes around the tube socket and place ventilation holes on the bottom plate under tubes to allow convection cooling.
I have been wanting to build another amp and this one is on my shortlist. I can't decide between a nice lower power push pull with 6BQ5's or the like or this amp.
I also forgot to mention your output transformers laminations should be at right angles to the pt. You could also place them at an odd angle like Cary does on their amps but I think that you would have to actually wire it up and move them around to experiment with which location had the least hum. I have also heard that the laminations on output transformers should be at 180 degrees from each other, but I don't know if this is really necessary. I used the same James transformers on a 2A3 amp and the lamination direction isn't as obvious with a potted unit like these. The speaker terminals on the bottom should be on one side of the laminations and the primary connections on the other.
400VDC Solen
I was planning to use an 82uF Solen in parallel with 18uF more to equal the 100uF on the power supply. I have this giant cap laying around without anything to do with it and I wanted to use it here in place of the motor run cap suggested. The only problem is it is only rated for 400VDC, not 630 like I first thought. I know you usually want a bit of a margin but as you see I have zero. My question is.....do you think I should try it anyway? Is the worst case scenario a blown cap? Or worse? At this point I am planning to use it unless somebody here convinces me otherwise.
Another few questions....has anybody tried an Amperex 6DJ8 in place of the 6N1P?
I was planning on using the additional choke on the preamp tube supply, do you think one is enough for both sides of the tube or were 2 chokes used (5H). I happen to have one choke that will fit the bill if it is okay to use just one.
Man, this thing is going to be MASSIVE! I am laying it out on an 12x16 inch wooden chassis I built a while back, I think it will all fit but the thing is going to probably weigh in at about 40 pounds!
I picked up a Westinghouse 10H 0.2 amp choke to use here but the dang thing is giant and ugly. I think I am going to raise the heigth of my chassis on the back and tuck this thing underneath the surface of the amp.
Additionally, I really don't like the idea of having my inputs on the front of the amp, any good tips on shielding so I can assure I don't pick up any noise on the way from the rear RCA inputs to the preamp tube (which will be mounted upfront and center) I have some bery nice shielded cable I was planning on using with the shield connected from only one end to earth main. Any additional ideas on this?
Thanks,
Jeff
LED bias for 6N1P?
Wavebourn .. pardon me if I may ask you how to wire up a series of LED in place of the 1K/100uf used in the cathode bypass? I'm a newbie! :confused:
Your suggestion to use 24K on plate and 360R for cathode is GREAT!
Despite the reduced gain, no problem with my 604E's 101db, sounds sweeter with deeper bass. :D
Thanks!
Zekk
Do you have to use polarized electrolytics for bypass caps for the 100uF/25V and 220uF/63V values?...
Can you use non-polar MKP capacitor instead, like Mundorf MKP Supreme, Auricaps, or Clarity PX, or Solen Fast Caps without degradation?...
I can't find values for Black Gate caps since they've been long out of production. Any advice on top tier alternatives?...
Chassis ready to go
Here is a sloppy pic from an Iphone of my chassis, ready to go. I will try to post some better pics later when I have access to my camera. The wood from bottom to top is Cedar, Canary, Rosewood, Canary, Madera, and Oak. You can see my hugh, ugly, 200mA 10H Westinghouse choke mounted up underneath. I just got all of the parts in a couple of days ago, should have her together in a week or so.
Jeff
Thanks Jeff for suggesting the Elna-Cerafine and the Nichicon KZ Muse caps. I'll try Partsconnexion. I've heard the Elna-Cerafines have 98% of the sonic attribuites of the Black Gates. I wonder how they measured that, but it seems good enough!... Oh, hey I see you've put the cart before the horse, but the enclosure looks distinctive. :)
