hi TeaBag
Can you help me with how to connect the boards to my najda? The najda has one 5 vdc input (2 terminals) so I will connect the 5 v bib section to this. It also has 12v +/Gnd/- though(3 terminals). I am wondering as +12v on bib has 2 terminals(well 4 if you include the sense circuit) and also -12v on bib has 2/4 terminals on bib as well and it seems they are both separate circuits. Can I connect 2 of the outputs of the bib to make a common ground on the 12v side and that way have the 3 outputs +12/gnd/-12 that I need?
Simon
Simon
Connect all the 0 sense and 0 force cables from both polarity sections to your GND power input point on your circuit. Connect +F +S to your +12V power input point. Connect -F -S to your -12V power input point. Twist each sense pair of cables as it leaves each regulator.
Thanks SalasConnect all the 0 sense and 0 force cables from both polarity sections to your GND power input point on your circuit. Connect +F +S to your +12V power input point. Connect -F -S to your -12V power input point. Twist each sense pair of cables as it leaves each regulator.
I seem to have low voltage when doing it this way it drops to 5.8 when connected to najda. I have 12v +- when connecting to dummy load resistors though. What do you think is wrong. I have dual coil outputs on my transformer. should the 2 wires be connected for the centre tap maybe?
Simon
Continuation from GB thread. Another thing Salas, my +ve 12 v was set using 13.5R but the -12v was set using 21r resistors. The reason is the najda documentation says to use .25A minimum for -ve.
Connections I used was S+ and F+ to 12v+
S- and F- to 12v-
The other 4 0v S and F joined and go to GND/0
S- and F- to 12v-
They can be different if surely sufficient for each rail's transient max. If you can't fit all those wires, close locally at the regs connectors F+ to S+, F0 to S0 and so on and so forth for the negative. Make them normal two wire output regs in other words since you can bring them so near to the load. Connect with few wires as if with standard output type regs. So we see if something changes. If not, scope the rails for possible oscillation(s).
There could be a stereo linear pot with a value comparable to your R103 & R203 replacing those. The trimmers could bring the range base voltages together so to ensure voltage tracking. Because its a pot that will be connected in the heart of Vref(s) you should ensure that no interference is picked up by wires. Better use shielded coax, ground the pot's body etc. Haven't tried that, if it brings oscillations, noise, etc. it may well prove just non doable due to side effects.Salas is there any way to make two sslv into a tracking +/- power supply?
- Power Supplies
- SSLV1.1 builds & fairy tales
