The regulated voltages (at least some of them) are produced by the small power supply.
On the output transistors, find the legs that are directly connected from one side of the amp to the other. The outputs that do NOT have their source legs connected to the other side of the amp are the ones you want. The source legs of these should essentially be connected to the anodes of DP10 and DP11. Do you read 0 ohms between the source of those outputs and the anodes of those diodes?
- General Interest
- Car Audio
- Soundstream XXX6500
