Soundstream XXX6500
Look at the attached images. You can see how DP11 connects to the points I mentioned. +24VEE isn't now connected as shown. You have to determine why. The jumper should have restored the connection.
Arrow has them.
The voltage on the anode must be higher than the voltage on the cathode for current to pass through it. Here, you'd need the voltage on the anode to be higher than 0.6v. It's currently 94v too low. This isn't a problem. It appears that you've restored the voltage to this part of the circuit. What is the DC voltage on pins 8, 9 and 14 of the driver board?
