Q51 (MPS8099) is 1-E, 2-B, 3-C and read 1 = 0V, 2 = 44mV, 3 = 105mV.
Q38 (J175) is 1-S, 2-G, 3-D and read 1 = 0, 2 = 105mV, 3 = 5.5mV.
I did my best to get the right pins but I am not sure I am indexed correctly on that.
That is what the pad measures with the Q51 out of the circuit. The base and emitter pads read 0V
Unfortunately the lead for the base pulled out of the transistor when i was removing it. I'll have to replace it either way.
Does this narrow it done or do you see any other possobilities. If i have to order it i would like to order anything else that might be bad.
None free. I might be able to find one at my work. Or I have a hifonics tourus amp with serious problems I could rob from. I dont see any 8099s but lots of other TO-92 transistors.
Yeah!!! Its working good. Q51 (MPS8099) was replaced and the amp is working. Thank you so much for all the help. This was an awesome experience and I couldn't have done it without you.
Is there anything else I should check at this time after making these replacements (bias or anything else)? It sounds good and seems to have full power. This is just awesome.😀
That's good news ! I am happy for you.
Bias for this amplifier is supposed to be 25 mvdc per channel.
I am currently running 3 subs in series for a total impedance of 12 ohms mono on a 5.2 and it's doing well. I also have the Airbass accessory for it.
azrt - Thank you for the schematics as well. Couldn't have done it without those either. There is a toggle for the airbass on the board, not on the front panel - is that what you have "on". Mine also has the "Hawkins" bass control. Do you use that? I have 2 - 4ohm subs in parallel. I will play around with some of this when I tune the system. Thanks.
- General Interest
- Car Audio
- Soundstream Class A 5.2 Won't Power Off
