Some other Source Follower Configurations
Someone asked about modifications to the DAO follower as built by Steen.
This is the version with the Taylor Current Source.
The 2SJ103 should have about 8mA Idss.
Depending on JFET Vgs variations, the resistor values might need adjusting. I should start with a 1k trimpot for R1 to set DC offset to zero first.
Hope you'll build this. Total dissipation about 15W.
Patrick
can you more specific about heat dissipation for each JFET and MOSFET
Thank's
Just built my Dao
Built 1 ch of my Dao amp. So far only 1 puff of smoke.I lost a J511 because I had it hooked up wrong! Thats sad news. I only ordered 4. I will have to order 1 more to make the 2nd ch.
I can not comment to much about sound, etc. I am waiting to make sure it is stable. I built it P2P and just want to let it settle in before I do any evaluation or drag out a set of real headphones. I will take it all apart and countersink the mounting holes, lap the sinks better and swap from sil-pads to mica and goop.
I have it hooked up to my Mini Aleph supply pcb. +/- 20 V with a CRC. total OVERKILL !!!!! I will look into building a supply soon. Pics will come later.
Steve.
Hipcheck,
For a really overkill p/supply, use one of Salas's "beefed up" shunt regs!
No suprise, noticeable difference.
For a lower power consumption, there is a double Cmultiplier design available but I don't think it's been designed or tested for 250mA - I did try a simplified double version of the CMx part of the basic Teddy-Reg (pink fish media) with the H44/45 transistors - quite reasonable results.
Works really well with a "Lightspeed Vol Control" - simple systems ....
... my 2 cents
hi all,
in an attempt to make a simple headamp, i wired 1 cahnnel of 2 lu1014d in a follower config, exactly like the DCB1. now i thought it would be plug and play. the sound is not bad. but i get input offset of 150mV or more if Vds get past around 8V. are these jfet not optimal in this config to start with and must they be used with 3V vds only to sound good?
sorry, i ll reformulate.
i wanted to experiment with simple headamp using 4 leftover lu1014d only.
can i use them exactly like in the DCB1 and get decent performance, playing with current and psu voltage?
or must they be used in triode mode only like in the DAO (which sound sublime :))?
Very interesting project there Patrick, nice job! I have a question regarding load resistance. Will DAO drive a 85 Ohm or 100 Ohm Orthodynamic headphones? I've tried to read this threadm but I found that load must be 25 to 67 Ohm for perfect results.
And will TCS or XCS can help DAO to drive bigger loads then 67 Ohm. 100 Ohm is maximum that I need. I've seen square wave with 200 Ohm load that gives overshoot. Can you put mesurements for 100 Ohm with standart DAO, DAO + TCS and DAO + XCS.
And last question is about es9018 with SEN V18 I/V, will this configuration work together with DAO amp?
100 ohm // 200 ohm = 67 ohm.
Therefore, you can still get perfect square wave by paralleling the 100R headphone with a 200R power resistor at the output of the DAO.
For ES9018, R_iv is 680R. This should be low enough to drive the DAO.
But if you have long cables in between, then perhaps you might need a JFET buffer.
It's a matter of taste.
Patrick
