SOAP MKIII (Simple OpAmp Pre) With onboard PSU
Puffin said:
Zei. Yes, but not in the way you mean!
I have lots of other things to finish before I lather the SOAP
Boy do you need HELP!
korben69 said:
Nothing to modify if using LM4562 ?
I checked the data sheet before inserting the chip and it appeared to be of a similar spec. I am not sure if the circuit has been optimised for the opa. Any ideas?
In the short time I've had it running I think it sounds a little bit crisper... slightly more detailed.
I will now swap back to the OPA to confirm this...back in a mo
Richard
