ZM asked me about this in the L'Amp thread and I've written up a mini article in case it should be of use elsewhere.
Look here: Audiohobby.com | DIY Audio Projects & More
one quickie question , but don't feel obliged to even think of it , if you didn't already messed with - had you any experience with 2SK60 ?
I haven't tried those. No one has sent me any for proper disposal.
Hi Mike, ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I tried to build the SK82 SIT with your text in my Multisim....
and I build the small test circuit of your homepage...
when I run the simulation occurs an error and the assistents says he does not know the parameter "KP" "Mu" "VCT"...etc.
I must say I am an baby in building parts and I suppose I did not find the subcategory "triode" in my MultiSim 11...![upsidedown :usd: :usd:](https://files.diyaudio.com/forums/images/smilies/usd.gif)
Recopy the text from my blog Audiohobby.com | DIY Audio Projects & More. I was doing some editing in the wee hours. Sounds like you're missing a + in front of PARAMS.
The category matters not, I use the JFET symbol and wire the pins up in the component wizard, then you just paste the model text in.
Merci beaucoup , Mr. MR
I have
VERTICAL FIELD EFFECT TRANSISTOR AND ITS APPLICATION
TO HIGH FIDELITY AUDIO AMPLIFIERS
BY
HISASHI SUWA, AUDIO DIVISION &
AKIYASU ISHITANI, SEMICONDUCTOR DIVISION
SONY CORPORATION
NEW YORK, NEW YORK
PRESENTED AT THE
51st CONVENTION
MAY 13-16, 1975
discusses 2SK60 and 2SJ18
The pdf is too big to upload but I can email it to anyone interested if you can accept a 1.5 MByte pdf
Thank you for your efforts, Michael. ![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
Your models seems good.
We DIYers do well to remember that capturing a nice schematics in e.g. LTSPICE and getting nice simulations is not at all all of the work. It only gives us a small hint that we are on the (hopefully) right path (towards audio nirvana
![violin :violin: :violin:](https://files.diyaudio.com/forums/images/smilies/violin.gif)
shoot at >sasica5@gmail.com<
I will place it in my Dropbox , so others will see it
sent
- Simulating SITs
