Simplistic NJFET RIAA
Joined 2006
Hi buzz.
The folded cascode provides higher output swing tan the telescopic at the expense of power dissipation.
diyAudio Chief Moderator
Joined 2002
Salas,
Rigol 1052 or 1102
They are the same machine. 50MHZ is plenty for audio projects. They just bias a varicap in the analogue front end differently via firmware and slap a different model label. Their fan can be a nuisance. That is if you breadboard or repair for long and you need concentration. Changing it voids the warranty.
