R1 values with 1 Tx & 1 reg. are:
Left 2k76
Right 3K06
The 2nd Tx has arrived, do you want the new measurements with 2 Tx & 2 regs.?
If you shut it down and turn both at 3k3, then power up and measure at BC550's collector, what are the voltages? Because you can set the voltages in other ways (by trimming R source) and not create much different custom Riaa networks between channels.
Salas, I mesured some 170V' s, here is what I got:
16.61
12.71
14.09
12.60
13.14
12.88
12.86
11.67
13.98
14.74
12.73
15.03
17.70
13.48
14.28
12.25
What do you think?
Sorry Merlin, no 10.5ma yet.
Looks like 13-15mA would be the majority?
Ok I will measure & post.
I would say betewen 12 and 15 ma.
Do you want to mesure more?
Any ideas what to do with them in a phono?
Will we get better results than with bl?
Measure some more if you can. You know, if the centre has a +/- 2mA useful spread it will no be much productive for calculating or building around them a general schematic. Comes down to hand picking and adjusting values around each build then. Its they can give more gain around the head amp but I don't know yet if they will be a better thing overall, or it will be just adjusting for them, have to experiment a bit with simulation. Their Ciss could be higher though. Lower noise and THD are possible on the other hand.
Now I have to cook for my other half!
Some good Greek recipe, I would guess.....
I'm going to cook some bucatini all'Amatriciana too for some friends before the big match Chelsea vs Inter tonite!
With R1 3K3:
Left 6.8V
Right 9.4V
Forza Inter
With R1 3K3:
Left 6.8V
Right 9.4V
We have to balance. Both are strong, but left is a problem. There must be 12mA running on the left and 11mA on the right. We wanted around 10mA. What you have for R2? One resistor or a combination? What multiturn trimmers you have in hand? Having any 50-100R? Or any small resistors?
I would just need to add 1-2R to the left channel. That will not give much control if putting in series, if the Shinkoh were 27R we could parallel the trimmers and have control. Or maybe you have LSK that matches better the right for bias on the circuit? That would be easier... Say if you put an LSK that brings around 9.5V to the left, we can keep 3.3k R1 steady and matched between channels so Ricardo can reference. You got them on pins, yes?
- Analogue Source
- Simplistic NJFET RIAA
