Congratulation it's very nice your phono preamplifier!! (Chapeau bas!...)Hi Salas,
I fixed the earth screen.
C2Y's are now 200pF. Combined with the 15nF C2 cap, that is is what I went for.
Did I make a misstake with those? I did not know this was cartridge dependant....
You never know before testing. 200pF proved bit much in your case so go nothing or lower C2y in any order that is easier for you and judge the balance now that you are somewhat familiar with the integration in your total system room included
Yes that was a completely off topic technical question about your friend's system. I have answered you, check.
That's why I asked
These are the ones that are in now: http://www.hificollective.co.uk/components/amtrans_amch.html
I will replace them when the clarity caps arrive with polystyrenes 100pF. Not tonight... no time :-(
Maybe those AMCH are doctored polypropylene "tone" caps to soften the usual rough edges in many systems but not needed in yours or its just the value that does the slight softening business, you will know in practice. Don't destroy their pins when pulled maybe they will come handy in combination with the Clarity C3 or not. Change the Orange Drop C3 when time comes, but put pins for C2y so you can experiment without lifting the boards with empty, polystyrene, AMCH. Even without pins the pads are plated through so you can just touch solder and the connection will be complete to both layers.
- Analogue Source
- Simplistic NJFET RIAA
