They look like good amps. I only had used Manley studio gear, and it was very good. Their vocal mic pre VoxBox was so much better than the Avalon. Only I had to repair it because it had fallen off a backstage rack. Just a phantom power switch damaged though. A worn out head amp valve too, but a new 12AX7LPS went in, and it rocked.
Hello again!
I've just been tuning into this thread once more. It's been many pages since I last posted, so I don't know what I may have missed.
Anyway, I'm now using a DL-103 (Aluminium body) with a step-up transformer into the 40+dB version that I previously used with the DL-110. Sounds good to me, but I'm wondering if there's anything to be gained by eliminating the transformer and making the 60dB version?
A better transparency and a bit better SNR arguably, you eliminate much interconnect and winding wire, but it is a rather big effort and spare of resources if you already like the results and your transformer is notable and expensive. Tell me the turns ratio and termination resistor you use.
Yes it's the standard 103, but I've removed the plastic body and put it in an aluminium shell. (Worthwhile improvement).
I've tried higher loading, but found that I like 100R best (which I think is what Denon recommends?) - the lower impedance gives more body to the sound
They say 100R is minimum on their leaflet. Its true, the lower the load, the heavier they sound. With 40R source impedance we lose signal on 100R loading non the less. Maybe you have noticed that the output is stated always more than advertised, on the individually measured spec at 47k. But sometimes they tune carts on typical loads by judging their tone on such loads when they make them. 100R is a traditional load for MC. Give it that a system leans towards heavier or lighter tone, and everybody has a favorite load. Me I like it when I have balanced tone by not needing to load the cart less than 10:1 so I have all the signal, but if it needs to change so to balance out a system, then no worries. My 103R with 14R coils sounds just OK with 150R for instance in my system, and that is good for both considerations.
Hello Salas & Jonners
you've both the right opinions. My experience shows as well that step-up transformers and step-up amplifier stages are different in handling.
Please let me note that some audiophiles have the opinion to use the same load as the cartridge owns - here 40 ohms - which is in fact nothing more as the so called power matching. This was used in the past in radio stations and / or tone studios. I'd recommend to play with a potentiometer and find the best sonic value.
Maybe an additional stage with 20dB gain is the better solution when using a solid state phono stage.
Bravo. What cable did you use for the remote sensing wires?Two new 4 wire shunts ready for trial !!!
I could not set both for the same current due to differences in the leds.... One produces 260mA and the other 240... hope it does not affect the stereo presentation too much.
* The ground can be extended without punishment for sheelding purpose.I am using 0,8mm multi strand silver cable... four in total.
Due to the actual layout it is not viable to use screened wire (The GND and +Vin in the Riaa boards are 5cm apart).
* Some users reported gain from a thick (2mm diameter?) wire between regulator and phono board. If I remember correctly the argument was lowering output impedance. It might prove an acadamical exercise on 'not top of the bill' builds.
Different questions
Hi Salas & everybody,
First of all sorry for the following a lot of of questions:
-I own a Denon DL-304, ultra low output voltage: 0.18mV & I want to do your Salas Simplistic NJFET Riaa but the schematics shown are for cartridges with more output voltage, I see your schematic for Denon DL-103 Stnd Gain 60dBs but I mind that I need more gain due to the fact that the 103 output is 0,3mV. Is possible changing the schematics get more gain? or I need to buy other cartridge with more output? because I disagree the set-ups
-I have several LSK389 on hand, is possible make the simplisitic with these other njfets? is necessary to change something or simply put half LSK389 instead each 2SK170?
-Due to the fact that I will do mine own PS, I need to know: how many VA for the transformer is needed (I suppose will be the same for all shunt regulators)& will is the voltage needed at the seconday depending each combination for the Universal Simplistic Phono Shunt Salas 2009.
-Where can buy with good price: matcheds for RIAA BC550C, & no matcheds for Shunt: BC546B, BC550C (I suppose the same like in "matcheds") & IRFP9140. For other shunts no matched: IRFP9240 or IRPF9620, IRFP240 or IRPF9620.
-For digital use: ic, clocks, oscillators etc. will be interesting to know how can do a shunt for 3.3V, is possible?
Thks in advance for your patience & kind advice
merlin el mago
merlin el mago
Thanks for you quick anwer, sorry to don't tell you before all the information needed about mine system, I am using:
-Balanced line preamp Erno Borbely with dual PS closed loop gain 20.8 dBs + 6 dBs balanced mode.
-Two mono power amp 75W RMS into 8 ohms Class A Erno Borbely
-Wilson Audio Cub 94 dBs 4 ohms
Now I am using like phono front end: cartridge Linn Arkiv / Denon DL-304 + Linn Linto + Ekos tonearm + LP12 + Lingo but I am not satisfied with the sound due to the fact that Arkiv first model specs are:
Stylus: vital
Tracking force: 1.55-1.75 g
Recommende load: more than 50 ohms
Weight: 7.4g
Separation 1 kHz: better than 30 dBs
Channel balance at 1 kHz: wthin 0.5 dB
Output at 5 cm/s at 1 kHz: 150uV
If you need the specs for Denon DL-304 (output 180uV) please be so kind to let me know.
I was planning to buy the Erno's phono with 73 dBs gain, because I suspect that the problem is the Linto phono amp that only have a gain of 66 dBs but like all Erno's line is a little bit high priced & in the same moment I read your interesting Salas simplistics njfet riaa & I take like a serious alternative
I know that are a lot of questions so I understand that you needs time to answer don't worry I am glad to wait.
Thanks again
merlin el mago
Stylus: vital
Weight: 7.4g
Thanks again
merlin el mago
- Analogue Source
- Simplistic NJFET RIAA
