simple passive preamp
............. using a high value resistor to shunt that charge to audio return/ground/cold. This also works if the capacitor leaks a little. Typically Builders use anywhere from 100k to 2M2.
....................Hints for how to work out value of grounding resistor?...........
I use 2M2 and this works for any plastic film input capacitor.
If you have a capacitor that leaks badly, you will need a much lower value.
That may explain why we often see 100k and lower being used.
i'm returning to this topic after a few month. i still haven't built the passive pre.
i just found this. no idea if it makes sense, but it sure looks good....:)
this is what the manual says:
"Position 1 Both channels keep common ground and both are connected to the chassis of TRUE
Position 2 Channel A and Channel B keep separate ground to output A and B without connection to TRUE chassis
Position 3 Both channels keep common ground to outputs without connection to TRUE chassis"
under what circumstances would one choose those settings?
