carlosfm said:Don't tell me you can't fit some heatsinks or cpu coolers in this space.
I see some space here.
that gap is like 3.5cm X 4cm X 16cm perhaps a heatsink.. but NOT a CPU cooler... yes.. I can fit SOME heatsink in there.. and I will try...
SkinnyBoy said:umm.. no it won't....
Yes it would.
You may have to cut a little of that l-shaped aluminium so that the fan fits, but it would do.
There are (were) some thin PII coolers, about 2cm thick (the heatsink), and about 1cm more for the fan.
Remember, hot chip means problems.
As you have it, you can't play your music loud, the chip will protect itself against destruction.
lol, and when the music is good, turn up the volume!
carlosfm said:
Yes it would.
it won't fit...
- Chip Amps
- Simple amp with DC on the output...
