Thanks to my friend jazz35 we have a document with CD mechanic modifications.
https://drive.google.com/file/d/0B-QF0EAtUuteQkNLdTZCX2tkVjg/edit?usp=sharing
Attached as pdf as well.
Regards,
Tibi
Regards,
Tibi
Well, I was wrong, the difference is perceptible.
It's my turn to thanks Erik for trying ...... ;-)
Did you try it as well Tibi....and thanks but we all three have to thank eachother
Right. Thank you Dimitrios !
Regards,
Tibi
I have a question...of the trimmer we modified ......only two pins from the three are being used....contrary to a volume pot meter.
Am I correct in saying that those are the two on the right side close to eachother...
(i do hope so since I noticed a difference..lol)
Two of the three pins must be connected to eachother in order for a variable resistance so it probably does not matter...?
Yes, only the two on the right side.
The left one (middle one) is connected to the top one.
Regards,
Tibi
Regards,
Tibi
So a "fail safe"....I have to learn so much more
For "experts" still recommending X5R/X7R and other MLCC's for decoupling in audio.
David L. Jones has just posted a video
https://www.youtube.com/watch?v=2MQyQUkwmMk
and here is a document from Kemet http://www.kemet.com/Lists/TechnicalArticles/Attachments/62/2007%20CARTS%20-%20Reduced%20Microphonics%20and%20Sound%20Emissions.pdf
No wonder why Shiga is sounding so good now. ;-)
Regards,
Tibi
Regards,
Tibi
Just found that David had a video with piezoelectric effect as well.
https://www.youtube.com/watch?v=KFCRB4d991E
"Experts" please enjoy !
Regads,
Tibi
Ps. "Experts" may understand now why Shiga high-grade have smd parts mounted vertically.
Regads,
Tibi
Thanks for clarification no I go to work! Do you us AG solder here also?
Steve
I use Ag as well, but I think is easier to solder with Pb.
Regards,
Tibi
I hate solder with silver... Mostly because there is no Pb in them and it's very easy to mess up. You also have to be very careful with your positioning tactics... No moving around and stuff...
If you are not (as Tibi said) a guru with black belt and 10 dans in soldering I would forget it in difficult places. A cold joint with a spec of silver is not going to be better than a proper silver-free joint.
Thanks for the input, is there a way to check continuity of the first mod the single XR5 replacement? Is there an access point for this circuit that you can get to with a multi-meter? Also I was thinking about using a good solder paste and heat gun possibly on second mod, do you think there is resist on pcb, or is this a totally off the wall idea?Does Ag solder work well with heat gun or is solder iron best do you think? I have 852D+ hot air. Thanks once again
https://docs.google.com/file/d/0B-QF0EAtUuteQkNLdTZCX2tkVjg/edit
In first page you have connector drawing. You should check continuity with ground pin 9 and respectively pin 1 and 2.
Pin1 is for Vref=2.5V decoupling and pin2 is for Vcc=5V decoupling.
Regards,
Tibi
Quick question about V1 and V2.
I m thinking of giving them one shared transformer and diodes.
Or should I use a third transformer too? Going way overboard with diminishing returns?
To be honest I would be perfectly happy closing it as it is I am more curious and playful right now rather than expecting more improvement...
By the way, where do we attach the ground and V+ for the external super regs? At the middle leg of the socket for ground and not dotted one for V+??
For V1 and V2 one shared power supply should be OK.
Ground point is at J6.
Super regs V+=5V must go to middle hole.
Regards,
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
