SEWA - Seven Watt Amplifier
I can't understand what's happening. I've double-triple (and more...) checked the PCB in conjuction with the diagram, but nothing found.
V+ = 22,5 V, BUT when I connect it to the SEWA, it falls to 8V!!!
I seen no shortcircuits, no mistakes on the PCB.
PCB= Rev.1
Diagram=Rev.D
Differences=R6(I put 1k, by Rev.D) R2(100K, by Rev.D) R9(100K, by Rev. D)
C7, which I have not put it yet.
Is there something else should change?
Here is PCB and parts, except capacitors:
Chokes question
Hi Choke Masters Circlotron and Fuling!:D
I need your help to make a minimum 120mH 3A chokes!
I found a workshop wher they could make the EI core chokes, but they need the:
- EI core size
- gap distance
- turns number
- wire diameter
I think about a 300VA EI transformator core with 0.25mm gap and ca. 200 turns of 1.5mm2 wire. What do you think?
Could you help me and give some info????
Greets:
Tyimo
