SB Acoustics Satori Monitor
Here is harmonic distortion at medium volume and spectrum at 200Hz and 1.1kHz. This driver is exceptional clean. Second harmonic is the lowest i measured, third is low too.
The 1.1kHz spectrum has just 0.3% THD, the spectrum at 200Hz is around 1%.
  • Satori Bass harm dist medium.pdf
  • Satori Bass spektrum 1,1kHz.pdf
  • Satori Bass spektrum 200Hz.pdf
Here are the multi tone measurements, also very clean and inverse FFT ( Gerhard Test ) even lower then the tweeter. The tweeter will of cause not get the full energy over the whole band because the crossover will lower the energy under 2kHz.
  • Satori Bass Gerhard Test Invers FFT.pdf
  • Satori Bass Multitone notched.pdf
  • Satori Bass Multiton high.pdf
I have measured the T/S parameters of the Satori woofer. My results come out close to the published data of the 8 Ohm model. I have somewhat less Qm and a bit lower Qts.
A QB3 reflex would come out at 15 liter so this driver works well in a rather small enclosure. I decided on an slightly over damped alignment in a 20 liter box.
In that box -3dB is around 50Hz. In room the extension will go into the 30th. I think pushing such a small driver deeper makes no sense but it is a very good performance in a compact cabinet. Also quite ideal to add a sub later.
  • Satori 16cm T-S.txt
  • Satori 16cm 4 Ohm box information.pdf
  • Satori 16cm 4 ohm 20 l frd.pdf
  • Satori 16cm 4 ohm 20 l imp.pdf
Joachim,
I don't know if you read the issue 4/2012 of the "Hobby Hifi" magazine where they tested the 8 Ohm version of the Satori mid-woofer?
It seems like your distortion measurements doesn't show the same second-order distortion peak at the cone-edge resonance as they measured, which is a good thing. :)
I wonder if SB Acoustic made any changes to the design?
/Göran
I have that issue but the drivers that i have do not show distortion at the frequencies.
I checked that several times because i know that this can be a problem.
Maybe they got early prototypes.
That's great news!
However I don't think the importance of the second-order distortion peak at the cone-edge resonance should be over exaggerated.
I have the same issue with my AudioTechnology 15H mid-woofer and it's one of the best sounding mid-woofers I've had in my possession.
AudioTechnology 15H520613SDK Measurements!
I think a pair of Satories will be in my shopping list soon. :D
Where could I get the 4 ohm version?
/Göran
