jean-paul said:
Wrong thinking, Bricolo ! You'll never get that much wanted stock this way
I'm sure you only need 160
just a small question besides this discussion (and a big HI to JeanPaul!)
I'm planning to build a power supply to feed 3 4th order crossovers. (that means driving 24 single opamps) The idea is to build this powersupply:
http://hitechnetworks.net/bwaldron/audioelectronics/sb1_regulator.htm
Since the standard 4700µF capacitors have a rather large impedance, I planned to replace each 4700µF capacitor (that are C15, C16, C21, C22 in this schematic) with 4 United Chemicon SXE 470µF/50V capacitors in parallel.
The capacitiance is 40% of what the schematic says, but the ESR of those parallel capacitors is WAY lower than with one 4700µF, and the max ripple current is about 2 times as high.
Is this a good idea to do?
Grtz, Joris
P.S. The specs of the 470µF SXE's: 0.068 Ohm maximum impedance at 100kHz (20 degr C.) Maximum ripple current at 100kHz (105degr C.) is 1320mA
Grtz, Joris
A big HI to you too Joris ! The idea of replacing the 4700 uF caps for 4 x 470 uf just for very low ESR makes not much sense. In ripple calculations the capacitance value is the one you're calculating with unless you're dealing with a switcher.
So you have to know how much current your 24 opamp crossover will draw. Then use the rule of thumb ( or look up the formula if you wish ) that one 2200 uF will suffice for 1A of current draw. Now calculate how many 470 uF SXE you need before the regulators. I am confident 4 x 470 uF will suffice with modern opamps. Nevertheless calculate things. Why not use 8 x 470 uF if you have them ?
But... I wouldn't use low ESR caps *after* the regulators.
BTW we are threadjacking.
Jean-Paul/ who hopes Jan Didden is around for a theoretical backup.
Neither would I unless you want an oscillator.
fdegrove said:Hi,
and after a shunt reg (TL431), is it ok?
According to the ON-SEMI datasheet, yes.
fdegrove said:Hi,
What does the datasheet say about that?
Not to use a 10nF<cap<1uF ?
Did I understant dut curve correctly?
But I didn't find anything about the cap's ESR
Nothing I could find so I think it's safe to assume ESR of CL doesn't affect the shuntreg's performance on paper.
Even upto 10µF can be unstable as shown in fig.15.
Note also that the unsafe area varies with Vref.
Bernhard said:Hi Bricolo,
1 EUR for 1 piece ?
I could not find a websit where they sell any.
Seems to be difficult to get that stuff
that's too much for me, sorry
Sorry I can't give a direct link, because when you go th theyr website, you are "logged", your url ends with a session id, and is invalid after some minutes of inactivity. That sux
www.radiospares.fr
on the left menu: "actifs et passifs", then "condensateurs", "aluminium", "polarises", and on the 3rd page you have 3 types of OSCONS.
Tell me what you think of theyr prices
www.radiospares.fr
- Design & Build
- Parts
- Sanyo OS-CON any good ?
