i found an interesting thread too (subject: glitch energy, OS)
http://tinyurl.com/yr4j9c
tubee said:
Which fir filter do you prefer then, 4X, 8X, internal in PCM dac,
PMD100
tubee said:Logic timing errors?
Way too slow for that. Far more likely that something is inverted that shouldn't be.
Thanks Hachiman for link. They talk about Guido's nonos dac, PCM1704 running on 16 bit too.
Rfbrw, have you done something to reduce jitter in clock signal out of PMD? Only curious. But problably not, you don't like reclocking if i am not mistaken.
The pdf of universal logic doesn't invert clock into shift chips.
Listened to the experimental cdp i have with 1541 nonos for a moment this afternoon. It can not reach the clarity of the pcm56's. There seems to be more noise in the music too, like a slight rumble, but then around tones.
PMD100 is not easy to find:
http://cgi.ebay.com/Pacific-Microso...70669875QQihZ009QQcategoryZ4663QQcmdZViewItem
What is this obsession with jitter? I keep expecting to read 'Bush appoints Fred_D to spearhead War on Jitter. Confirmation uncertain.'
But the clock to the '74 is inverted.
I wouldn't expext much from the TDA1541A, no matter what its worshippers and their High Priests say.
tubee said:From: i found an interesting thread too (subject: glitch energy, OS)
The second factor is linked to glitch energy.
Inside the audio band a NOS converter will have measurably lower distortion.
The opposite is true for low level distortion.
Linearity improves with higher sampling rates.
A PCM56 usually measures better in 8x os, compared to 4x os, both with deglitcher.
A TDA1541A suffers from bypassing the SAA7220B.
For full scale I don't know.
Now do you have a working schematic for the PCM56 non os ?
Can you listen to music without artefacts ?
Via SPDIF it is easy.
Logic not ready Bernard, had some other things to do (repair laptop)
I listened to the same last cd as listened with pcm56, and same gear (tube headphone amp + AKG h.phones)
Have some questions:
What is the maximum voltages that the PCM56 is to be run at?
What's the voltage swing when using passive I/V using say 560R?
What happens if I feed the DAC with 24bit data?
AD1851 and AD1861 (18bit) are pin compatible. Anyone tried them? Good idea to use sockets
Anyone settled for a 'definitive' glue logic I2s 'converter'?
See datasheets.
But some even run a TDA1543 or other on higher voltages then stated in datasheets.
Pcm56 is 16 bit, no more bits will be processed (the 16 bits related to MSB are used, even feeding with 18, 20 or 24 bit)
Right now i am listening to it, it has still some very small artefacts with beginning of tracks, at the track itself it dissapears. I used the universal shifter, recommended, for universality.
http://www.geocities.com/nonospcm1704/universal_shifter.html
For other dac tests i only have swap the shift wires.
I havent shielded the logic, nor decoupled the logic chips yet!
But sounds good.
Play a cd with a 'crowded' track in which many voices are recorded. CD Doe maar, Klaar, track 12
For the first time i can understand what they say:
"Het is wel druk hier. Laten we ergens anders gaan zitten."
Btw tried an other cdp as base, maybe this could declare the previous problem. Will swap clocks, now use Tents XO.
I can correct now easily MSB on ear with low level signal music by means of headphone. The digital noise dissapears, and there is the best adjust point. But the Right channel i can not get completely silent, the pot is at his end. Another PCM56 dac could be tried for R, and see if this one is better adjustable for MSB.
Indeed the MSB adjust is very very important, no adjust gives low level distorsion.
The culted TDA1541 doesn't have MSB adjust, is stereo, so it must be hard to select a good sounding stereo pair, lots of dac chips has to be selected and small percentage of them will pass.
Have a handfull of 1541's and should sell them in future.
The XO gives an analytic sound, but can be slightly sharp in treble. Experienced that in previous cdp's. Kwak 7 was more analog sounding, will try Kwak on the PCM56's
tubee said:I can correct now easily MSB on ear with low level signal music by means of headphone. The digital noise dissapears, and there is the best adjust point. But the Right channel i can not get completely silent, the pot is at his end. Another PCM56 dac could be tried for R, and see if this one is better adjustable for MSB.
Only use the chips marked 63. The other two are not good and one is outside the adjustment range, those were only to hear the difference. Best throw them away.
The adjustment range can be made more wide or narrow or shifted by changing resistor and pot values.
I think it is best to make the pot as small as possible to avoid temperature drift.
Also a temperature stable voltage reference should be used for the supply.
Parallel chips and using MSB on one chip only will further reduce drift.
tubee said:PMD100 is not easy to find:
Hi Bernard
I have only two PCM56 dacs, not four, and are not stamped.
I swapped the dacs and the very small distorsion stays at R, so the regulators and/or caps could cause it. IV i swapped too, no difference. But as i said this distorsion is very small, L is very clean and i want both channels clean. Have to decouple each logic chip also. Was surprised it worked allmost immediately, after correcting 2 fault this morning, yesterday i was soldering with a fine glass of red wine
Will add the dacs beside the logic on the perfboard pcb and keep room for some extra PCM's
The universal logic has also a provision to feed dacs differential (Q-not output of flipflop) This could give another 6dB or so noise cancelling imo. But have to find out about I/V then, i want to use a passive I/V resistor and tube stage, have parts allready.
Bernard, did you made the MSB adjust schematic for only 1 of the four dacs? Would it be possible to adjust each dac, and listen/adjust each dac by a switch or jumper? Then after all 8 dacs each are adjusted, they can be paralled again. Idea?
Guido, have you bought this lot?http://cgi.ebay.com/Pacific-Microso...70669875QQihZ009QQcategoryZ4663QQcmdZViewItem (i ask because of your smile)
Ups, I recently sold a pair of selected PCMs + two bad ones.
I thought it was you...
Very possible one of your PCMs is outside the range.
Have seen that even on K's.
tubee said:Bernard, did you made the MSB adjust schematic for only 1 of the four dacs? Would it be possible to adjust each dac, and listen/adjust each dac by a switch or jumper? Then after all 8 dacs each are adjusted, they can be paralled again. Idea?
I made MSB adjust only for one DAC, all 4 together behave like one, MSB currents are added and adjustment range is only 1/4 of normal.
Adjust every single DAC is useless.
- Digital Line Level
- SAA7210 to PCM56, a Dutch-American connection
