The higher value resistors may have problems turning the FETs off quickly at high frequencies. If you're only going to use it for bass, it may not be an issue. If you want to make sure it will be OK at higher frequencies, set the crossover to all pass and drive a 10k sine wave up to clipping. If the current draw doesn't increase as the signal level approaches/reaches clipping, it may be OK.
- General Interest
- Car Audio
- Rockford Punch 301m
