Rockford Fosgate Punch 800.2
Is there any DC on the output of that channel?
If not, short the bias transistor from collector to emitter with a jumper wire and remove the jumper from C5. Does the amp power up and idle?
There is a small amount of DC on that channel about 0.220 vdc, but I soldered a jumper from collector to emitter on Q308 and removed the jumper from C5 and the amp pulses.
0 amps to 40 amps over and over.
