Are M1, M2 the right types in the right places and not accidentally swapped? Is your Rx/J/D position resistor making sufficient contact? Recheck. Leds cathodes should be at the square pads. You can check without removing them by using a 9V battery. (+) wire to round pad, (-) wire to square pad. Touch the wires just briefly to each Led's pads. They should light up one by one. If not, they are either reversed or overworked with the iron and gone.Help! Checked all part values but LEDs won't fire up. As far as I know the LEDs are in the right position, according to the manual. Have taken some pics, perhaps someone has an idea? Thanks! :lifesavr
Good news; how did the output voltage work out?
If you're still interested, there's a picture of my Reflektor D units in use here:
http://www.diyaudio.com/forums/group-buys/227502-amanero-isolator-reclocker-gb-168.html#post4190472
Ray
Ray
Thanks for your help. It's working now. There was nothing wrong with it to begin with apart from me not leaving the power on long enough for the capacitors to charge. I know, not very smart and overcautious.
Its C2's large value. Important for filtering the LED Vref well below 1/f down to seismic subsonic area. Because clocks can be peculiar to subsonic noise. But has to charge up sufficiently first with the ~2mA current mirror bias available there.
Hi Salas,
Today I can built the R-D. It was very easy to build and it working at the first power up.
I need anyway your confirmation that I am in the safe and correct side.
I need the Vout 3,3V at 600mA.
The R1 is the parallel of 1,5 and 1 ohm = 0.85
I first used the 1 green led and the 62 ohm as R6.
Whit those value, with a load of 5 ohm I can get 3.24V.
To reach the 3,3V stable after 30 minutes I need to increase the R6 up to 136 ohm ( 2 x 68 in serie).
With the values above the R-D is nicely stable at 3.3V and the heatsinks are hot but not so hot.
I am quite sure that the R-D is properly setup but I would like to have your confirmation
Thanks and Regards,
Enrico
Thanks and Regards,
Enrico
Hi Salas,
Thanks and Regards,
Enrico
Hi Enrico, by what you describe it seems well set up.
Great!... Thanks Salas
Collecting parts for a Reflektor-D build (3.3V out).
I do have some parts in my drawers, for C2 I would have 470uF SilimicII or 1500uF Pana FM or 1000uF Pana FC.
Any preference from your side, Salas... or just try any of them?
I would prefer a 1000uF Nichicon Muse. 470uF Silmic II is good also but not as deep down below 1/F noise filtering value which can be detectable a bit or not at all, depending on the client circuit. But a smoothie in the audio band. Pana FC is good and dependable but bland in the mids & highs. Better in energy storage than in filtering positions.
You are welcome. Good luck. Will be nice to see your finished application and know your impressions, when done.
I will need some time, too many thinks are ongoing around the dac, but I will do it.
Enrico
Is it for a Buffalo?
If your question is for me, no is not for a Buffalo but for a Edel_NMR.
Network stuff then. Interesting.
Yes... I will let you know when I am done.
Enrico
Joined 2006
Hi Salas,
I ordered some reflektor and BIB regs from tea bag for the sdtrans384 sd card player and the associated syncDAC, which contain separate digital and analog sections.
I understand there are about 15 or more embedded local LDOs with Oscon caps in those sections...and after reading the following posts of yours,...would I need any adjustment to the regs, as you mentioned about tweaking the open loop gain etc and on the stability issue with bypass caps..? Please advise and thanks
Post #509
http://www.diyaudio.com/forums/vendors-bazaar/246003-modifying-subbu-v3-dac-51.html
Post #6083
http://www.diyaudio.com/forums/powe...ic-salas-low-voltage-shunt-regulator-609.html
Post #509
Post #6083
Posts #151 - #155 here show how to tweak OLG and decide which suits best. You will need an extra K117GR per Ref-D.
Stability issues don't premeditate, tackle them only if they will happen in a certain regulator-load system. Too complex to predict in not fully analyzed combinations. Oscon caps are not in the low value nF category so they usually curtail the reg's bandwidth enough not to trigger odd interactions. Simply check the rails are tame when done if you got an oscilloscope. In case of a problem we will examine the system and we will see what we may tweak.
Joined 2006
Joined 2006
This is very encouraging, something I was hoping to see
Will try out R6 vs FET.
In post #156
http://www.diyaudio.com/forums/power-supplies/261031-reflektor-d-builds-16.html#post4070364
In post #156
- Power Supplies
- Reflektor-D builds
