If I try mkrom I get :
mkrom 1021fil2.txt
Soekris Engineering mkrom utility vers 0.85, 20150112
Invalid filename 1021fil2.txt
mkrom 1021fil2
The file 1021fil2.txt exists in the working direktory which also contains mkrom.
What am I missing? (I am Mac guy, maybe I do somthing stupid DOS-wise)
As the instruction says: "mkrom 1021filt" - note the file name, it's hardcoded as the utility do other things, all based on the filename....
I am thinking to get this dac, but it can work with Raspberry Pi, I2S with piCoreplayer?
I have used Voyage Mubox for the Raspberry Pi as well as Volumio for the Raspberry Pi with Soren's DAC. Both via i2S (i.e, no USB or SPDIF interface). Have not used piCoreplayer.
mkrom 1021fil2.txt
mkrom 1021fil2
beaten to it by several hours....
you can only use
Code:
mkrom 1021filt
the input file must be named filt1021.txt
Thanks, I got it working this way.As the instruction says: "mkrom 1021filt" - note the file name, it's hardcoded as the utility do other things, all based on the filename....
I had interpreted the instruction in the form that "1021filt" was only a template for the filename and gave different filter sources different names.
But if the produced .skr is renamed and uploaded to the DAM102, the DAM will recognize this as new filter settings, yes?
For the Mac(UNIX?)-people if you instal Wine, mkrom can be executed by typing in the terminal "wine mkrom 1021filt".
yes. the name is irrelevant, as the dam1021 only "sees" the uploaded binary data. The .skr files have a header that starts with a soekris ID, file size, and then a string that is consistently the same between filter files and different in the FPGA file. I'd assume this is used by the uManager firmware to determine the function of the uploaded file.
Hi there.Thanks alot for your information.
In addition to this.
Do you think this can be used?
HiFimeDIY i2s/DSD Isolator 384kHz HDMI to TTL interface
Its got the same receiver that the fidelix type has. And the fidelix hdmi transceiver module has the same tranceiver that the gustard u12 have.
Thanks in advance.
Trying to test with i2s in from this Gustard U12 and hdmi(lvds) to i2s connection.
I actually god "lock" on the signals the soekris dac but no sound. Dead silent
External 3.3v is connected to the isolated i2s side of the dam1021 and to the hdmi-i2s receiver.
EDIT: Well... turning the amplifier ON helps every time..
My goodness... Yes we got sound..
Best regards.
i have been there and done that.
Soren,
for the filter header:
I had a filter with multiplier 0.9 which resulted in no output (multiplier 1 worked, also multipliers 1.1 etc).
If so could it be changed with the firmware update so that the multiplier gets a double. That would ease life ... you would not need to multiply all coefficients.
it seems that the multiplier is treated as integer, true?-- Format:
-- signature, samplerate, interpolationrate, type, numbercoefficients, multiplier
Soren,
Hmm, looked at the source, it's integer, was float at some point and should really be float so I will update the mkrom utility.
Update: corrected mkrom.exe should now be up at usual place, see post #1486 if needed
meant to say which chip is it because i need to replace itwhats the 1.2v smps reg?
It's a TI TPS562209, but please note that if you killed that part it's likely that the FPGA also died....
yea i know
gotta try it though
thanks for the info
from hifiduino
this fellow is answering one of my questions (#1920):
INITIAL POWER MODS
The power on/off POP seems benign if listening through headphones. The power-on pop is not loud at all. The power off pop is loud. If connected directly to an amplifier, it can potentially damage the loud speakers.
During Power off, the positive rail drops faster than the negative rail and this creates a voltage imbalance resulting in a huge POP. At some point, the device is practically powered by the negative rail...
https //hifiduino wordpress com/2015/02/22/dam1021-r-2r-dac-mods/
i'm just a beginner but i wonder if i use a rectification of 3v 0 3v center tap
that gives me 8.10 dc does it cure the voltage imbalance (that seems to be happening when the 7v 0 AC is used)
thanks
Martin
INITIAL POWER MODS
thanks
Martin
For how long now?Mine is running 24/7. No problems. Powered with 7.5vac
Same here. Running 24/7 to avoid dealing with shutdown pops. Power from a 2x7vac transformer.
The DAC runs very cool - I can't detect any warmth to the case beyond ambient even in +30°C conditions.
Someone on another forum even suggested that running the DAC 24/7 might be beneficial to sound quality.
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
