Hi Soren,
Dam 12 is out of stock at several days, when do you expect have a new batch ready to go?
Thanks in advance!
They're being made, should be no more than a week now.
I am interested in this dac. I have questions, probably already answered, but there are 740 pages to read!
I have 4-way active DIY-speakers.
1. Can several boards be synchronized (clocks), to be used in active multi-way speaker? And not getting out of synch after a while?
2. Anyone using the dac as crossover-filter successfully?
3. Can volume-control be controlled toghter for several boards? Can 0dB be set as the max gain? (I do not want positive digital gain by mistake)
4. Examples of builds with multiple boards in the same chassis would be nice to see. Can boards share power-supply?
5. No pops/dc-output on startup or shutdown with recent boards?
6. Link to independent measurements?
7. Pops/clicks on sample rate changes?
8. Is the noise-floor ”state-of-the-art” with this chip? I want low noisefloor.
I will probably have more questions later on. I am tempted to build a 8-channel dac with this chip.
If no answers are given, I can not buy this, off course.
I'd be curious to know the answers or an example implementation too.If no answers are given, I can not buy this, off course.
Hi everyone,
Could I ask for everyone's expertise?
I'm trying to connect my raspberry pi2 to the serial dam1021 connection.
I’m using the pi2 as a source for digital audio (I2S) and this works perfect and I would like to use the pi for connecting to the DAC with serial connection. I connected as follows:
Dam1021. ...........Rpi
J10,Pin3 Rxd — pin8 gpio14 tx
J10,Pin5 Txd — pin10 gpio15 rx
J10,Pin9 Gnd — pin39 gnd
I’m using the latest Raspbian Jessie.
I setup serial configuration in raspi-config; enable serial, disable login.
Also /boot/cmdline.txt has no ttyAMA0 mentioned.
Also I setup /boot/config.txt has
Also serial-getty is disabled;
doesn't mention ttyAMA0
is executed.
has UART pins (15 and 16 wPi, pin 8 and 10 physical) in state ALT0
Working with minicom wasn't a success and I read somewhere it it's not always reliable, so I setup the serial port with 'stty' and open serial connection with 'screen';
With stty I setup ttyAMA0 port;
(Bautrate, no parity, 1 stopbit, no flowcontrol, no s/w flow XON XOFF)
With stty read back settings;
A lot of information but every option with a - in front is disabled, without - is enabled.
Check if ttyAMA0 port is being used;
If necessary kill session;
With next command I start serial connection;
(Only port given, for the rest 'screen' should use the setup from system/stty)
Quit screen with Ctrl-a d
Unfortunately all of the above doesn't work. When I start connecting with ttyAMA0 then whatever I type is not visable in 'screen', so when i type +++ it doesn't do anything.
I could connect Tx (transmit) with Rx (Receive) and test if anything sent to Tx is received at Rx, but I assume i should at least be able to connect to the port.
I probably missing something, does anyone see what?
Code:
enable_uart=1
Code:
ps aux | grep tty
Code:
sudo systemctl mask [email]serial-getty@ttyAMA0.service[/email]
Code:
gpio readall
Code:
stty -F /dev/ttyAMA0 115200 -parenb -cstopb -crtscts -ixon -ixoff
Code:
stty -F /dev/ttyAMA0 -a
speed 115200 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^H; eof = ^D; eol = ; eol2 = ;
swtch = ; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V;
flush = ^O; min = 100; time = 2;
-parenb -parodd -cmspar cs8 -hupcl -cstopb cread clocal -crtscts
-ignbrk brkint ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff -iuclc -ixany
-imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon iexten -echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke
Code:
ps aux | grep ttyAMA0
Code:
sudo kill -9 pidnumber (first number in list)
Code:
sudo screen /dev/ttyAMA0
Why don't you use minicom ?
Regards,
Tibi
I tried. Same thing happend.
If I do
Code:
sudo minicom /dev/ttyAMA0 115200 8N1
When I open minicom and setup all settings in menu I can see that I type +++ but nothing happens
Or use the isolated serial port. It's 3.3V TTL level.
Where can I find the isolated port Dimdim?
Edit: Aah on J3. Shame on me, never noticed those connections. I will try. Thanks!!
I think you need a TTL to RS232 converter.
MAX232 is one to look for.
Regards,
Tibi
Thanks Tibi, I will keep that in mind. Will try isolated connection first. Signal level should be the same between the pi and dam.
Hi everyone,
Also I setup /boot/config.txt hasAlso serial-getty is disabled;Code:enable_uart=1
doesn't mention ttyAMA0Code:ps aux | grep tty
is executed.Code:sudo systemctl mask [email]serial-getty@ttyAMA0.service[/email]
has UART pins (15 and 16 wPi, pin 8 and 10 physical) in state ALT0Code:gpio readall
(Bautrate, no parity, 1 stopbit, no flowcontrol, no s/w flow XON XOFF)Code:stty -F /dev/ttyAMA0 115200 -parenb -cstopb -crtscts -ixon -ixoff
A lot of information but every option with a - in front is disabled, without - is enabled.Code:stty -F /dev/ttyAMA0 -a speed 115200 baud; rows 0; columns 0; line = 0; intr = ^C; quit = ^\; erase = ^?; kill = ^H; eof = ^D; eol = ; eol2 = ; swtch = ; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V; flush = ^O; min = 100; time = 2; -parenb -parodd -cmspar cs8 -hupcl -cstopb cread clocal -crtscts -ignbrk brkint ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff -iuclc -ixany -imaxbel -iutf8 -opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0 -isig -icanon iexten -echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke
If necessary kill session;Code:ps aux | grep ttyAMA0
With next command I start serial connection;Code:sudo kill -9 pidnumber (first number in list)
(Only port given, for the rest 'screen' should use the setup from system/stty)Code:sudo screen /dev/ttyAMA0
wait a minute if this works then i wont need the amanero usb/i2s adapter? i could just use Rpi to do that? i have an Rpi3 that right now has volumio in it. this would be great.
Theoretically should work. I’ll report back.
However on a RPi3 it’s suppose to be a little bit more difficult because by default the UART interface is being used for the internal Bluetooth device. Are you using Bluetooth?
If not there is a relatively easy way to swap them.
i am not using bluetooth at all and dont plan to
Please read the second solution here:
pi 3 - How do I make serial work on the Raspberry Pi3 - Raspberry Pi Stack Exchange
Edit: more in-depth information you'll find here, but that's for the rpi 2, only difference is the way they share the uart device (explained in previous link):
pi 2 - Why my program won't communicate through ttyAMA0 on Raspbian (Jessie)? - Raspberry Pi Stack Exchange
Admin: Hope it's okay to post these links here, if not please let me know
Connected to pin 14+16 ISO rx in+ISO tx out on J3.
Used minicom and one sec after +++ I got reply from uManager.
Updated my dam1021 to the latest fw but now don’t get a lock and thus no sound.
I read something about problems with this latest fw 1.19 so I will try fw 1.06 this evening.
Happy I finally solved this and can use my good old pi for this.
Thanks for the help everyone.
Don't forget to power cycle your dam after firmware upgrade.
Regards,
Tibi
Oh forgot to mention Tibi, I did power cycle the dam (not the pi/i2s source)
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
