Question on input noise current
This is not necessarily true for extremely low source impedances. Some bipolar transistors have base spreading resistance as low as 1ohm...2ohms (BFW16A and family), and in any case, you can make the total base spreading resistance as low as you like by putting devices in parallel (for AC). For extremely low source impedances and 10mA of total current, one BFW16A still outperforms your ten high-transconductance JFETs (1.3ohm+2ohm<5ohm). Assume a non-negligible source impedance and/or skip the current limit and the JFETs win again.
I agree, BUT most circuits have more than a 2 ohm source. That is the problem. I actually patented the quietest low inherent distortion bipolar input stage for a given current, about 30 years ago. I don't use that circuit anymore, because the FET's do better, overall.
diyAudio Retiree
Joined 2002
actually patented the quietest bipolar input about 30 years ago
Well that's fine ..... but what have you done for us lately?
Sorry John. I couldn't resist, knowing you must have a highly developed sense of humor to keep at this subject this long without a well deserved rant at everyone. I believe Bob Pease wonderfully described it as "being nibbled to death by ducks."
Fred
PS
We do enjoy a "don't hold back, tell us how you really feel about it" rant once in awhile and I try to have at least one a week.
diyAudio Retiree
Joined 2002
Nibbled by Swedish ducks...........
"I notice that this thread is about a measurement problem but you talk about noise in general, typical thread jacking."
I guess I don't quite understand what you are talking about........
The name of the thread is "Question on input noise"
The first post by Crister http://www.diyaudio.com/forums/showthread.php?postid=239325#post239325
talks specifically about input noise sources and refers to documents specifically about input noise sources for amplifiers and op amps.
Would you like to start a a thread on measuring noise and the problems involved in making low noise measurements? I am sure that Mr. Curl would have some insight on that and AWL has made many low level measurements on power supplies and should have some advice. It might be a good place to mention the low noise transistors, op amps, and PCBs for low noise phono preamps on your website.
http://home.swipnet.se/~w-50719/forsale/index.html
Fred
PS for a real example of real thread jacking see my previous one in this thread.
Eh, well, no. The thread isabout noise, input current noise
or noise in general. I started it since thought the noise discussion
in another thread was getting close to threadjacking. I mentioned
the measurement amp because Marcels comment
on noise for non-matched source impedances seemed relevant
here.
PS since I started the thread I suppose I have a say about
what is threadjacking or not, so I decide it is OK to discuss
measurement amps too. :)
