If amplifier output power is most important to you, see post #8, no need for those smiles,550 W with + /- 65 V dc
Regards zeoN_Rider
Old 'RCA' is very valuable parts,
Yes, but i have only 5 of them. Used - but working o.k. in testing circuit as constant current source.
regards
frank
That's enough for 2X120W/4R amp, and you have one for serviceYes, but i have only 5 of them. Used - but working o.k. in testing circuit as constant current source.
regards
frank
OK, no smiles !
Regards zeoN_Rider
Crown DC300A used four pair 2N3773 on ±65V for 300W/4R x 2 (1.5KVA transformer).
That what I talking about!
Regards zeoN_Rider
See post #39,Crown DC300A used four pair 2N3773 on ±65V for 300W/4R x 2 (1.5KVA transformer).
2N3773 150W SOA at 70V, 150W at 100V (±70V rails max)
MJ15024 160W SOA at 80V, 100W at 100V
MJ21196 240W SOA at 80V, 200W at 100V
See post #1 and #2,post46.
surely not, not even for ClassB.
The output to VAS cap?
The missing Re on output?
The missing driver emitter load?
to lose >20V between quiescent PSU voltage and maximum peak output voltage is very poor performance.550W is maximum power for this circuit, not with +/-65V.
With +/-65V DC output power will be about 250W on 4R load.
I would expect >200W into 8r0 and just under 400W into 4r0 from +-65Vdc when biased to quiescent currents.
550W into 2r0 is a reasonable short term target while the output devices are still cool. I would expect better from a 4pair output stage.
This is old simple circuit, and poor performance are expected for retro design, but work good and easy for made. This is amp for begginers as I say, for make expirience and have fun.to lose >20V between quiescent PSU voltage and maximum peak output voltage is very poor performance.
It's look like :
Regards zeoN_Rider
This is 50W/4R amplifier, PSU on pcb you need only 45v ac transformer, 'NEPTUN' real retro if you don't like old Dynacord.
50W, piece of nothing
regards zeoN_Rider
I agree, all input and VAS with using just one single BC286...50W, piece of nothing
regards zeoN_Rider
If you can have PSU without voltage drop with full output power, you can get 120Vpp or 42vRMS output voltage with +/-65V DC rail voltage. That will be 225W/8R or 450W/4R with 1% THD, or 300W/4R with 0,1% THD like CROWN DC300 with 1,5kW transformer. Power is not important, this amplifier give great chance for begginers to made functional amplifier.to lose >20V between quiescent PSU voltage and maximum peak output voltage is very poor performance.
if power is not important then why call this a 550W amplifier?Power is not important, this amplifier give great chance for beginners to made functional amplifier.
Why do you show a 4pair output stage?
Why do you show +-65Vdc as the supply?
I would suggest a beginners amplifier should start with PSU <=+-50Vdc, 1pr output stage and specified for the real power into 8r0., not this monster of 550W. That is approaching what CAR Audio can only think about - POWER is all!
Stage 2 is the option to add a second pair to improve the current capability of the amplifier.
- QUASI Amplifier for Beginners
