Hello Folks --
I am far from a DIY'er w. my one and only DIY being a Hafler DH 101 preamplifier built in my teens. Recently dusted off my Quatre DG250C and feeling in a rather vintagew mood, wanted to press it back into action. With great trepidation, I plugged it in and connected it to my 4 ohm ELAC speakers and lo' and behold, it sounded pretty good.
Based on my reading here and other places it seems that this amp is prone to packing it in giving up the ghost and taking speakers across rainbow bridge with it -- especially with 4 ohm speakers. So to my questions...
Was it all iterations of the DG250C or were there versions that corrected this propensity. Is there a S/N range that is considered OK? Below are pics of the boards in case that helps.
I know this is an old thread, but I'm hoping you fine folks can assist.
Thanks in advance!!
Richard
Thanks in advance!!
Richard
My QMI GC-200
[Note: This is cross-posted in the "Quatre QMI Gain Cell Series Amps" thread.]
I know this is a long shot and I maybe shouldn't even be posting here, because to be honest I am not an audio DIYer. But you all seem very knowledgeable, so I'm hoping you'll be willing to help a noob.
Back in the early 1980's I was a wannabe audiophile and acquired the following:
Last week I unboxed it all and started hooking things up. I started with a tuner, pre-amp, amp and speakers. Lo and behold it worked! I then tried adding the sub-woofer between the pre-amp and amp and got silence. At one point I did hear the characteristic hum and managed to turn off the amp and pre-amp before hearing the pop. I do get sound when I plug headphones into the pre-amp. I get no sound from the sub-woofer when I connect it to the pre-amp. The speaker line fuses didn't blow and the speaker cones move freely. None of the amp's fuses blew.
So what to do? I'm a decent troubleshooter (40+ years as a network engineer) with a multimeter. I also have a Pioneer SP-SB32W sound bar with RCA inputs. Should I even try troubleshooting and, if so, what should the first steps be? Or is everything so old that it would need to be upgraded even if I wasn't having problems? I'm assuming the cost for that would be significant.
Thanks in advance for any advice.
Bob
GAS Thalia II pre-amp
QMI GC-200 amp
ace-BASS B2-50 sub-woofer
KEF Corelli speakers
Various input devices
Bob
- Quartre Amplifier ???
