steenoe said:
Hi Tony. Didn't you make that layout? I had forgotten about it, but come to think of it I beleive you did send me some files. I will look for them on my PC when I get home.
Yes, you might be correct I sent you the art work for the double board for the ZV9 since yesterday I found the file. Anyway I decided to go over it to make it F3 worthy.
Let me know if the size of those PCB’s is OK for your amp layout.
My memory just isn’t what it used to be, sad but true
Re: Re: Re: Re: Arcylic turntable (again)
Thank you Steenoe, I appreciate the kind words. The turntable came out much better than I expected.
Here is another attempt at resizing and post at pic. I discovered I had my graphics program set too aggressively.
steenoe said:
Hi Steve. Thats a great looking turntable Nice work. The finished edges looks glassclear from here.
You can resize and make a smaller resolution in a picture program.
Try "Irfanview" its free and you can find it on the web.
Re: Re: Re: Re: Re: Arcylic turntable (again)
that's even more fugly!!!
It works!
Hurray!
Now that I can post pictures -- you've created a monster.
A picture of what I am listening to right now, and hope to be trying a Pumpkin/Shunty and F4 through soon:
Horn speaker based on Dr. Edgar's designs and using one of his poplar "salad bowls" for the midrange horn. The rest of the wood-working is mine. That's a downward-firing horn loaded subwoofer with 18 inch JBL pro driver, behind the left channel speaker. . .
Hurray!
steenoe said:I know nothin' If thats my name on that paper, there must be a conspiracy involved
I think you're being framed.
Dennis
Hi Tony. The size is just fine, thanks. YGM.
Wow, thats one nice TT. Great job. Is that shotgun-shot, in the platter?
Thanks for the support, Dennis. I have a hard time convincing Rovsing that I am innocent I do admit that the whole case
is pretty mysterious, though
Dennis
Re: It works!
man - now seriously - every detail on that picture is just right .
can you share your (I presume) joy about Edgar's with us ?
I mean - I know already pretty much about them , but is always pleasure when someone say something "in flash" ........
hehe - this thread is certainly good for that , as any else ....
btw - I just must say that - LL obviously discovered how to quote properly
zettelsm said:Hurray!
Re: Hi!
Thanks! Measure twice, cut once -- and no matter how many times you cut a piece, it will still be too short. . .
It was my first attempt at veneering. Good thing I had lots of sandpaper.
Seriously????? ZM, are you sure you are feeling OK?
The most realistic sounding speakers I've ever heard -- great clarity and truthfulness to timbre and texture and nuance. Instrumentalists and vocalists are *in the room* And dynamics that still startle me.
Amazing what a couple of milliwatts of tube power can do with 106dB/w/m.
I first thought about getting the hardware to make that big enclosure look like an armoir or antique upright ice-chest. Talk about wife acceptance factor -- I still hear about it. And on top of all that, I had to get her to help me with it when I ran out of strength on the next to last step at the top of the stairs! The thing weighs over 110 kilos.
I used up major points with her over that speaker!
dviswa said:Steve,
That is real fugly!!!!!
Man, that kind of wood working skills makes me Jealeous
zeonrider said:Wow, what a speaker, or is it a part of furniture !?
Regards zeoN_Rider
Thanks. You are absolutely correct -- lead shotgun-shot in twelve chambers around the periphery of the platter for mass and momentum.
I didn't turn the platter -- that was done by Chris Brady's brother. I was one of the original seven DIYers who participated in the design and building of the original Teres turntable project. He did the platters and bearing after we finalized their design.
The base and plinth, suspension and armboard are my design and fabrication. I'm using a VPI arm, and the VPI center and periphery clamps.
Steve Z
Steve Z
Re: Hi, zettelsm!
Like he is in the room!
zeonrider said:, tell us how Frank Zappa sounds on this thing of 2 x 110Kg-s.
Regards zeoN_Rider
Re: Hi, zettelsm!
I like Zappa. Personal! Unique! Sense of humour! His own!!!
Listening to tube and F4 thou . . .
zeonrider said:Frank Zappa
zettelsm said:Like he is in the room !
Frank is not dead, he just smells funny.
Not quite finished yet, but all the mechanical stuff and supports are done.
Here is a pic of the current state. Simple does it, I am striving for a very clean look, now that the lid is see-through The faceplate has 2 black knobs and one green (! not blue, for a change) LED.
steenoe said:...pheeew
Here is a detail shot of how the bearings are mounted.
Sheesh Steen... What's the RPM on those shafts?
Beautiful work, again and again, I give my vote for best implemente Pumpkin... so far.
ZM should be proud of you...
- Pumpkin preamp - ordered by Steen , official making thread
