Pumpkin preamp - ordered by Steen , official making thread
quote from ZenMod:
dunno for your pcb - but for mine correct way is like this
Thank's for the correction on my attenuator schm.
Well i tried to hook it up, the way you suggested, and some hum dissapeared.
look at zenmod's attennuator schm. here
I made a 'star' connection in middle of chassis (not connected to that) from that 'star' connection wires are going into these point's.
1 wire ---> pwr gnd Right channel
2 wire ---> pwr gnd Left channel
3 wire ---> signal gnd Right channel
4 wire ---> signal gnd Left channel
5 wire ---> comming from input gnd
The god thing is, that now my 4deck work's as good as my 2deck-stereo pot. :)
But still having that strange -in to GND problem... If i deattach the -in wire comming from attenuator, the :Pumpkin: is dead-quiet! ... But when -in is attached to attennuator there is comming some humming... really annoying. Donno what the problem is. Seem's to me, that it's some grounding issue...
Because when -in is connected to gnd via attennuator the :Pumpkin: is becoming very sensitive.. e.g when i touch some part's you can hear it. All that dissapears when disconnecting -in... something i didn't noticed before. I must say, that i didn't try it on my F4's this testing is done with my LeachAmp, there is ofcause the possibillity that there is no humming when connected to F4... but i sure would like to solve that problem anyway.
Jesper.
gimme pics ,drawings , whatever ;
you must have ground loop somewhere .
Yep... groundloop it must be! --- but no piccie's today, cause children bring along digicam on a weekendtrip :)
I realise, that i did not use the 'coax shield' in coaxcable. it might be the problem.
The coax i use is a 3wire+shield cable, containing red, black, yellow. + shield.
I use the black wire as GND, red is for +connection's and yellow is -connection's. The shield connection, i just leave as it is at end of cable's... I just looked at your'e grounding schm. HERE
And see that the shield is connected at the PCB (which i didn't do so far)... this might could be it ???
Will be back when rewiring once more ! ;) Not tonight for sure :D
Jesper.
Official Court Jester
Joined 2003
Jesper.
if everything is wired OK - then shield is just a bonus , not necessity
Joined 2003
lykkedk said:
If that's the case... i haven't no clue anymore... everything is connected proberly.
Will be thinking next few day's i guess... might be that i'll figure it out that way! ;)
Thank's for helping me out ZenMod... PS: check youre mail in few minutes... :)
Jesper.
gimme pics .
Magura said:
Remember, snaps December 8th Jesper :D
Magura :)
whazzat now that dec. 8. ?
