mpmarino said:Is this better Maggie? A two inch spade bit and a dremel is all it took.
A couple of words of advice:
Cover the faces of the workpiece with self adhesive film to avoid scratches.
Use you millingmachine and the tools I sent you for stuff like what you just did with your dremel. It's easier than you may think, simply draw what you need to remove directly on the workpiece, and do it freehand following your drawn lines by manually operating the feed on both the X and Y axis.
But looking good indeed
Magura
(I just wanna see what you'll invent as Brunhilde symbol )
Zen Mod said:
whazzat!?
ya sick today?
Naah, but he should clean up his workspace....all those chips on the table, are simply just waiting for a chance to make a dent or a scratch
Magura
El Marinero is starting his own Twisted Nut line, Brian and Russ will be jealous.
Zen Mod said:bust out all of my thread..........
I can't stand all these compliments............
Said the pathetic little ****, who will rater go to his sister in law's wedding, than his friends 50th birthday!
Happy now?
Magura
Magura said:pathetic little p****
You skipped a letter, Maggielyn.
Oh Jaccolina, what should I do without you
Magura
Happy now?
Magura
scratching my wound ...........
I'll hang you twice
Evening all...
I am having real big problem's with my volume control / inputselector etc...
Seem's to me, that whatever i do for now, it's ending up with huuuge hum/noise !
If i just connec't my old ALP's 10k pot - directly soldered on input and with -in connected to GND... the work's 100%...
Everey other attemp's failes for me for now. I tried to connect my 4deck, with some shielded cable, but ending up bad too. Maybee i should try using the shield as GND, like it's done when i attach my alp's stereopot, donno but seem's to me, that my is very sensitive for picking up unwanted signals... Could ofcause be, that i have set gain at 20x, but i am finding it odd, that i can succes with attaching signal/pot directly... ???
I would appreciate if someone can tell me, excatly howto attach my 4deck alps. I have some shielded cable i can use, but seem's to me that thing's must be done 100% correct to success. --- At the point i am now, it's close for me, i hate to say for giving it up...
Have a nice evening all.
Jesper.
Jesper.
lykkedk said:Evening all...
Jesper.
have you any schematic?
so we can see where is culprit ............
No i am just attaching 4deck directly... seem's that the -in/gnd connection is very very sensitive... it's like, that if i attach wire's here instead of a solderbridge, the humming raises real much... later i will draw a schm. how i attached my pot.
Jesper.
Jesper.
later ........ now I have things to do
don't worry - AR2 (in fact Sy and Anatech and Magura) were successful in that ..........
hehe - photoshop a little pumpkin and all hell breaks loose
This is very true. I should also refrain from dropping stuff onto the concrete floor!
lykkedk said:This is how i do it... correct ?
Jesper.
dunno for your pcb - but for mine correct way is like this
mpmarino said:hehe - photoshop a little pumpkin and all hell breaks loose
Re: Re: Pumpkin Pre chassis taking shape
Nothing directly, perhaps there's a package pick-up slip in the mailbox. I'll check again today.
Zen Mod said:
woodie ;
ya didn't see a postman yet ?
- Pumpkin preamp - ordered by Steen , official making thread
