Per, I mean that it will be not so easy ( I have not experience with it ), 'cos must be used soldering paste for soldering of pad. Device must be " preheated " in this case by hot air and all thrue holes must have correct diameter - soldering of SMD devices is " big science " .
SMD soldering with hot air
Upupa Epops:I see your point
We use this at work:Hot air soldering mashine
But what I meant was that it is not THAT difficult.
I wouldn´t have any problems using a regular hot air tool(don´t know what it is called in english,"varmluftspistol" in swedish) at home.
What matters is that you should NOT try this without getting used to this and try a it with some junk components first.
And not to heat the components too long...
Upupa Epops said:Yes, no problem with this machine , except price for this .
I´ll agree...
But it wouldn´t be that difficult to use a regular hot air gun like this:
http://www.tumstock.se/itemimages/full/0102434.gif
It isn´t the first thing a beginner in soldering should try...
I would not hesitate,but I´m used to solder things like this
I like the idea of soldering a copper wire, perhaps mains earth wire, to the pad as a solution. The chip doesnt get very warm at all and I've run it quite loud for extended periods and left it on for hours. I think the important thing is to earth the pad and give at least some conductance of heat. I'm going to build another to go inside an integrated chip amp I've got planned.
I've got some OPA4134 opamps as used in the suggested application on the pdf file - might try to incorporate those as well -any thoughts?
For the power supply, I used a transformer with twin secondaries and fed the outputs into 2 seperate regulators.
peranders said:I have not yet desided if I'm going to use a single or a dual supply. At least I have desided that it wll be an non-inverting buffer with gain and the TPA6120 will go a inverting amp with gain of 1.
I plan to use one AD8620 and one TPA6120.
P-A, why don't you use the TPA6120 alone, NI?
That way you will evaluate this chip.
An AD8620 before it?
Why?
Good question!
The TPA6120 has rather large bias currents which can cause trouble when the signal source is not known and/or you have AC-coupled input. Therefore to eliminate this I chose to have a buffer and when I have it I chose also to have an inverting configuration of the TPA6120 since I have good drive capability. It's not impossible to modify the pcb into a non-inverting, non-buffered version.
The group buy interest at head-fi.org is zero (to hard to build?) but if anyone here feel this headphone amp could be interesting, send me a message and maybe I will set up a group buy.
It's not ruled out that I can solder the TPA6120 but I won't promise anything.
Peranders - is the OPA4134 opamp a bad choice? TI promise 120db dynamic range using the OPA4134 and TPA6120 together. Have you looked at the Evaluation Model pdf document? I got more ideas from that than the datasheet.
http://www-s.ti.com/sc/psheets/slou169/slou169.pdf
- Headphone Systems
- PowerPad and the ultra extreme headphone amp TPA
