How do you mean? What type of headphones do you have?thomas997 said:I like it but its not quite powerful enough for my needs.
Some crappy Sony MDR or something. Not very good.
Its just that the output I have is very low, so I will try increasing the gain and see how it does.
Soldering is a little challenging. If you can find some sort of socket for it, that would help a lot.
Carlos: I tried with 12V as well, seemed to help a little. and yes i need to increase the gain. Just wanted to build it identical to the datasheet first.
There must be something wrong with your amp. There are a few TPA6120a2 running and nothing like this lack of power was reported. Check for example this thread : http://www4.head-fi.org/forums/showthread.php?t=74525&highlight=tpa*
peranders said:Altough with only gain of 2 your ears will hurt and 5-7 Vrms will make your headphones to glow.
Nah...
With a portable device?
I can bet that the mp3 player doesn't even get to 1V output.
500mv~750mv is common for portables.
You can't ask much more for a thing that runs with one or two 1.5v batteries...
Upupa Epops said:Hello again, guys . What do you think about this idea : ten of these chips connected in parallel will can easy drive an speaker box and I mean, that it will be more better than any Aleph or Hiraga . Any comments ?
Mmmmm...
Well... if you parallel another 10 and bridge 10+10, we may be talking more serious business.
peranders said:Carlos, I ment of course that the gain must be adjust for the application. If thomas has a weak signal he must increase the gain which is done very easily.
That's what I meant on a previous post.
2x gain is low, as he is testing with an mp3 player.
If the intention is to make a headamp for portables, gain should be much higher.
But the feedback resistor must remain as per the manufacturer's recommendation.
Indeed, becasue this is a current feedback amp where you also control the speed with the feedback resistor.carlosfm said:But the feedback resistor must remain as per the manufacturer's recommendation.
Tip for soldering pad
I cut a small rectangle of copper out - the width of the chip - heated a blob of solder on the centre with a gas torch, then quickly stuck the chip on the molten solder. I then hard wired leads to the active legs of the chip and made up the circuit as per the basic evaluation model.
It sounds very good - my friend has a Chiarra Single Ended Class A Headphone Amp - and he was a bit sickened to hear this almost free amp.
Re: Tip for soldering pad
Wednsday I'm going on holidays for a week.
Don't make me take the soldering iron to the beach, please.
ericallan said:It sounds very good - my friend has a Chiarra Single Ended Class A Headphone Amp - and he was a bit sickened to hear this almost free amp.
Upupa Epops said:How you can endure it - you must have realy big other inspirations, probably with nice t... !
Ah yes... forget the soldering iron...
Today I have started to convert my QRV04 headphone amp to AD8620 and TPA6120. I have great expectations in this IC.
The pcb will be easy to solder, even the "PowerPAD".
I haven't desided yet if the TPA6120 should run in inverting mode or not.
haven't checked the datasheet yet but it should be doable to solder.
here's a guide to soldering smd parts .
- Headphone Systems
- PowerPad and the ultra extreme headphone amp TPA
