Power Supply Resevoir Size
Transformer Spice Modeling and Scaling
All,
While in the process of getting ready to use the per-unitized transformer model parameters to update my spreadsheet, I had to transfer all of the equations from my LT-Spice simulation to Excel. So I first made a separate spreadsheet for just the transformer modeling and scaling.
The attached spreadsheet should be quite useful for anyone who wants to model transformers in spice or pspice.
Enjoy,
Tom
  • Transformer_Spice_Modeling_and_Scaling-Gootee_13OCT2012.zip
I'm not sure what you mean by the above statement. I believe that the output power is limited by the rail voltage for these cases, so the transformer VA is not going to play much of a role in output power.
-Charlie
Thanks for your help on this. I did misread Tom's chart. But, the unexpectedly low ripple (I was actually aiming at less than 2v, not less than 1v) is perfectly acceptable, considering the low price of it. Nice upgrade! So, let's just go ahead and keep the "less than 1v" ripple spec. I hope that "<1.0v" was the right way to type that (if not please fix). I'm not a math expert, but the clarity of a chart is very helpful, since I am able to make comparisons.
And, here is the capacitance versus VA question in chart form.
Constraints: 800va max. 1v ripple max. 40,000u max. 1 channel.
Please fine tune the capacitance for any case that is impossible.
The resulting applicable data will show matters instantly very clearly.
Code:
output  cap per   ripple                       secondary AC
power     rail   voltage  transformer   info     voltage
 8 W     3,300u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
 8 W     6,800u   0.73V    1.1a25vct   28.6VA  12.5+12.5vac
 8 W    12,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
13 W     4,700u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
13 W     8,200u   0.76V    1.5a30vct   44.7VA    15+15vac
13 W    15,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
22 W     4,700u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
22 W    10,000u   0.78V    2.0a36vct   71.3VA    18+18vac
22 W    20,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
29 W     6,800u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
29 W    15,000u   0.59V    1.9a40vct   77.9VA    20+20vac
29 W    30,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
37 W    10,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
37 W    20,000u   0.50V    2.2a44vct   97.5VA    22+22vac
37 W    40,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
50 W    10,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
50 W    18,000u   0.64V    2.7a50vct  135.7VA    25+25vac
50 W    40,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
65 W    10,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
65 W    20,000u   0.65V    2.8a56vct  158.5VA    28+28vac
65 W    40,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
95 W    10,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
95 W    20,000u   0.76V    3.7a64vct  234.9VA    32+32vac
95 W    40,000u   <1.0V    ?.?a??vct   ??.?VA    ??+??vac
I couldn't seem to operate your spreadsheet when approaching/passing the 100w figures, and I'd like to see a more linear behavior all the way to at least 180w, so that Tom's 125w, 150w, 180w (or so) amplifiers could be included. Here they are:
100.0W 20,000u 237.3VA
125.0W 20,000u 295.7VA
155.0W 20,000u 363.2VA
180.0W 30,000u 395.4VA
I'm sure that somebody will a power supply for the Honey Badger amplifier in this power range.
P.S.
In regards to the 0.99v or less ripple spec, I've noticed that my own power supply designs can filter 1v or 2v of ripple, but they don't always filter off 2v, in which case the audio quality may be either mid-fi or crap; so holding the ripple spec down below 1v is going to be much more compatible and consistently successful.
Code:
It's not that difficult, really... Only modify cells in bold blue text... Enter what you know (e.g. transformer VA) and then manipulate what you don't know (e.g. secondary voltage, ripple voltage) until you find what you are looking for. If you want to simulate higher output power levels, the secondary transformer voltage has to be higher as well.
I hate to tell you, but I'm not going to run all of these for you :( These tables are inane anyway.
I will be uploading an new version of the spreadsheet with some instructions soon, and will post here about it.
-Charlie
i can assure you i don't, i use sine waves on dummy loads.....i listen to music exclusively....:D
The picture above is the worlds most popular sine wave generator used in musical instruments. Prototypes from about 1928, patented in 1934, the Hammond Organ uses slightly dirty sine waves in an additive synthesis method of producing different tones. Newer all-digital models have recordings of mechanical tone wheel output and the most faithful of replicas pump digital tonewheel output through the same audio path as the original, including the key contacts, tubes and rotating horn speakers, thus reproducing the dynamically reactive behavior of the originals, faultlessly, along with most of the weight and cost. Even the 1-manual edition is fiercely heavy. Lighter weight options exist that subtract or supplant some of the steps in the audio chain and sound like less-authentic recordings of the real thing, but at lower cost.
All of this is tremendously popular.
AndrewT said:
We all listen to sinewaves. Even when simulated squarewaves and sawtooth waves are inserted into digitally created music, these are composed of sinewaves.
With the Hammond Organ as evidence, thereby, I suggest that AndrewT is correct and we have been listening to some sine waves.
In two current, relevant, and sizable industries, the Digital Hammond Organ (both authentic and off-brand) and the Digital Church Organ, are all extremely demanding of amplifier power supplies. If the power supply has either disharmonic content (ripple) or weakness (sag), these instruments would be about as fun as a flat tire. Since accurate replay is easier from the console than from a CD, I suggest that audio replay power supplies need to be even higher quality, by at least double the stiffness with half the ripple for a chance at some realism.
In related news: Due to audio quality caveats, Steinway still doesn't offer concert pianos the size of toasters. That's just another example of "no free lunch." :)
while music is made up from sine waves, there is no comparison with static sine waves, feed your speakers even 1 watt of 60 hz sine waves see if you can stand it....
i am talking about continuous sine wave, not the sine wave that has an envelope, attack and decay, something we call musical sounds...
Thank you again for editing the table. The results are high quality, practical, and definitely easy to read.
It's not that difficult, really... Only modify cells in bold blue text... Enter what you know (e.g. transformer VA) and then manipulate what you don't know (e.g. secondary voltage, ripple voltage) until you find what you are looking for. If you want to simulate higher output power levels, the secondary transformer voltage has to be higher as well. I hate to tell you, but I'm not going to run all of these for you :( These tables are inane anyway. I will be uploading an new version of the spreadsheet with some instructions soon, and will post here about it.
-Charlie
Where do I type in the capacitance? I'm sorry, but I haven't been able to exactly correlate Tom's spreadsheet with your spreadsheet any farther than seen previously.
This is not "instead of" your spreadsheet. It is 2 steps.
1). The goal of the table is to provide multiple practical examples at 1 glance as a fast (directed) place to start. In fact, it is directions. Some people will need that prefabricated guidance, for a head start. I do!
2). After having picked a practical near match example to investigate further, your spreadsheet gives excellent details on the specific behavior and the actual wattage output expected, as well as the shopping convenience of listing real transformers.
The effect of the table: In 2 seconds or less, I've been "tricked" into reading the directions. :) Yes, you're right that one table won't do it; however, it won't take a million either--It will take 4 to select the load:
Monobloc 8 ohms, Monobloc 4 ohms, Stereo 8 ohms, Stereo 4 ohms
But, the 4 tables can provide a practical and instant head start.
I find it necessary to narrow down the options so that I don't get stuck in simulation.
As I mentioned before, you DON'T enter the capacitance. You might intuitively think along the lines of how you would build a power supply: you pick a transformer and capacitors and then you see the result. That is not how my spreadsheet is set up, however. Instead, you pick a transformer and a RIPPLE VOLTAGE and then the capacitor value is calculated. Capacitance and ripple voltage are inversely related, so one directly determines the other. Unfortunately, the way I have formulated the spreadsheet, I need to know the ripple voltage a priori since it is used in the calculations...
So, back to your question about capacitance:
  • use the ripple voltage to control capacitance
  • reducing ripple voltage means that a larger capacitance will be required
  • increasing ripple voltage means that a smaller capacitance can be used
You have to iterate around a little bit in order to home in on a particular capacitance. This seems backwards to me - I would instead specify the ripple voltage (for instance something on the order of 0.707 volts seems to be what Tom's number give) and then just list whatever capacitance results from that. You won't be using a 1%, 5% or even a 10% tolerance electrolytic anyway in this application... This would allow you to remove the ripple voltage column and just note at the top that all the capacitance numbers stated give a ripple voltage of 0.707 V (for example).
I can understand your confusion about this.
At this point, I think that should get you started.
-Charlie
I am talking about continuous sine wave, not the sine wave that has an envelope, attack and decay, something we call musical sounds...
I see it, finally.
Multiple simultaneous sine waves is a lot more demanding on the power supply than one sine wave.
Thanks!
ripple voltage has a lot to do with your load resistance, not just capacitance, they have to be considered together....
this is from the National Semiconductors' AUDIO/RADIO handbook circa 1980, chapter 6....
1. Good Regulation means wCRl ~ 10
2. Low Ripple may mean wCRl > 40
3. High efficiency may mean wCRl < 0.02
4. Low cost usually means low surge current and small C
5. Good transformer utilization means low VA ratings, best with full-wave bridge FWB circuit, followed by full wave center tap FWCT circuit.
I see it, finally.
Thanks!
it would be interesting to compare actual energy content of music versus static sine waves....
static sine waves are used in analysis for lack of a better alternative....this issue have been discussed at length here many many years ago...:D
to keep out feet firmly on the ground, it would be best to know the difference, it has an impact(economic) on our choices as well....:D
You have to iterate around a little bit in order to home in on a particular capacitance. This seems backwards to me - I would instead specify the ripple voltage (for instance something on the order of 0.707 volts seems to be what Tom's number give) and then just list whatever capacitance results from that. You won't be using a 1%, 5% or even a 10% tolerance electrolytic anyway in this application... This would allow you to remove the ripple voltage column and just note at the top that all the capacitance numbers stated give a ripple voltage of 0.707 V (for example). I can understand your confusion about this. At this point, I think that should get you started. -Charlie
Am doin it. THANKS!!
Yes, now that you mention it, specify desired ripple target at the start, totally makes sense, being that it IS the quality control dial that will directly affect realism for LTP or noise for singleton. THANKS AGAIN!!!
EDIT!
I'm stuck.
Entering dramatically different transformer VA doesn't change capacitance like indicated in Tom's spreadsheet. I cannot synchronize the data to reflect (per same ripple figure) what happens to required transformer VA if you either remove half of the capacitance or double it.
EDIT!
I'm stuck.
Unless the power level is being changed somewhat significantly, changing VA won't change capacitance all that much. That's because power output is tied to RMS current which is tied to ripple voltage and capacitance. I'm not sure what numbers you are running, but for instance let's investigate a 25+25 transformer and fix ripple voltage at 1 V:
Code:
  VA   power  capacitance
300VA   48     36,177
200VA   45     35,173
150VA   43     34,251
100VA   38     32,382
 80VA   34     30,943
 60VA   29     28,560
What is happening is that, as the VA rating falls, the amount of sag increases. The ripple is being caused by the amplifier draining the caps, and I include both the current delivered to the load as output power and the current that is dissipated power (as waste heat) in this calculation. The total current only falls from 6.04 to 4.79 amps when the VA rating is falling from 300VA to 60VA. That ratio of 6.04 to 4.79 is 1.26 times, the same as the ratio 36,177 uF to 28,560 uF. The capacitance is just not going to go down by half if the ripple voltage is fixed at 1 V.
Personally I think that it is more instructive to see what happens when ripple voltage is allowed to vary (increase). As ripple increases, the available power will decrease and so will capacitance. For instance, let's stick with the 150VA 25+25 transformer:
Code:
Vripple power capacitance
   1      43     34,251
   2      40     16,662
   3      37     10,813
   4      34     7,898
   5      32     6,157
There's your big capacitance drop, and subsequent reduction in output power capability. You can look at the table above and read it right to left and see how reducing capacitance increases ripple voltage and decreases the maximum power output.
I seem to be envisioning the problem in a backwards (or reverse) fashion compared to how others are envisioning it. Maybe that is why we are having trouble getting on the same wavelength...
-Charlie
OK, the next revision of my spreadsheet is now available. I've changed some names and titles and improved some of the graphs, but the guts are the same. I've also added a worksheet containing info on the model, its assumptions, and some basic usage instructions.
Get it here:
Power_Supply_capability_calculations_VER2.2.xls
Here is a screen shot of one of the plots:
-Charlie
I am curious......now that we have a system of estimating transformer power using static sine waves, i wonder what is the correlation with a typical music? since nobody listens to sine waves....
Thanks for confirming that your statement was wrong and that your defense of that wrong statement was also wrong.
Yes, provided that the frequency, amplitude and phase of these sine waves are such that they add up to some approximation to a low frequency square wave. I thought we established much earlier in the thread that an LF square wave is the hardest thing for a PSU to cope with, in terms of current delivery and hence required reservoir capacitor value. Anything else is easier.
There may be a separate issue with things like IM caused by capacitor nonlinearity, but that is for another thread.
