As mentioned above, some of the cases investigated were showing a peak power that was limited by transformer VA instead of by rail voltage itself. I thought I would discuss how I came up with this factor.
As most people know, music has an average power level that is below, sometimes far below, the peaks in the signal. This can be captured in what is known as a "Crest Factor", which is the ratio of peak power to average power. So, your 100W amplifier might be on average producing about 1W of output power, however, brief peaks of 30W-60W might be common. Transformer heating should be based on the average power throughput. This is different than the peak power, which is determined by rail voltage.
In my spreadsheet, I calculate the power supply capability in two ways: one considering rail voltage alone, and another considering the average power that the supply must generate for a given crest factor (for music, this is typically 10-20dB). Given that the transformer should not over heat, I compare the rail-voltage-limited and continuous-power-limited peak output power, and then choose the smallest of the two as the limit.
Because the dissipation in the output stage of a class AB amplifier (at full power) is proportional to the rail voltage squared, higher rail voltages will result in higher power dissipation. The dissipated power must also be generated by the power supply, and gives rise to additional transformer heating. So, in the case of the 40V secondaries, above, the rail voltages are actually higher than the case with the 35V secondaries, so more dissipation.
This can be manipulated by the crest factor to some degree. For instance using a crest factor of 20dB changes things so that the transformer secondary voltage is the limiting factor instead of the VA rating. This just means your amplifier will not be able to work at a very high constant power level, or looking at it another way your 100W amplifier is really a 25W continuous amp with 6dB of headroom... it's just another design factor to consider.
-Charlie
-Charlie
I made a couple of additions, so I have posted a minor update, version 2.1.
The latest version is available here:
Transformer_capability_calculations_VER2.1.xls
-Charlie
- I fixed the plot in the transformer model worksheet that was blank.
- I added the rail voltage in the upper left plot on the "music program material" worksheet.
- I added a visual dashed vertical line in the plots on the "music program material" worksheet so that it was easy to see the different power limits for each.
-Charlie
I concur with AndrewT on this!
Practicality constrainments would make the spreadsheet a lot smaller, less misleading and easier to read.
I'd like to see a very small chart (with only low ripple selections), listing amplifier power, DC operating voltage, transformer, and power supply capacitance.
Here's some DC operating voltage (rails) selections:
8 + 8
13+13
15+15
18+18
22+22
26+26
30+30
33+33
36+36
40+40
44+44
47+47
51+51
57+57
What's missing is an affordable Low Ripple selection of transformer amperage, transformer voltage, amplifier watts (split rail monobloc) and capacitance, all on a highly practical chart. Estimation is okay. What I'm after is applicable data.
P.S.
If there's some data that even I can read, then new power supply designs can start from an orthodox basis for seriously improved performance.
8 + 8
13+13
15+15
18+18
22+22
26+26
30+30
33+33
36+36
40+40
44+44
47+47
51+51
57+57
P.S.
8 + 8
13+13
15+15
18+18
22+22
26+26
30+30
33+33
36+36
40+40
44+44
47+47
51+51
57+57
P.S.
Hey Daniel,
I invite you to use my spreadsheet to get this data yourself...
1. Enter whatever +/- (split) rail voltage you want (minimum 12V, max 60V) and transformer VA on the "transformer model" worksheet.
2. on the "music program material" worksheet, choose:
- dB crest factor = peak amplitude / RMS amplitude. Typical values for music are 10-20dB. Enter 0 to show continuous power data.
- load resistance, per channel
- number of channels in amplifier
- Vod: output stage drop-out voltage = Vrail - Vout,peak (typically 3-4V)
- Mains Frequency [Hz] (50Hz or 60Hz)
- Volt, Maximum allowable ripple voltage
You can investigate lots of scenarios this way... and since your interest in "low ripple" will be contrary to others interest in "minimum capacitance", each user should choose what suits them, or can investigate how the parts they have lying around will perform.
I'm currently working up an "info and instructions" page that should be helpful.
-Charlie
I purchased two ST-120 transformers, they put out about 72 volts each. Does anyone know what VA these two oldies carry? IF a mono block was built what would be a est. of watts into 8 and 4 ohms? What size caps would be recommend for the two rails?
You can weigh them. Typically about 2.2 lbs per 100 VA is about right. Do the transformers have dual secondaries or a center tapped secondary?
I have an update to post, so that my spreadsheet model is more flexible and you do not need to enter or measure the data for a transformer. I will give an example using AndrewT's post from above and show how my spreadsheet can be used to answer questions about the minimum capacitor size that can be used in a power supply.
For my latest revision, I went through a bunch of the Antek transformer datasheets, copied over the relevant parameters that were needed to model the transformer (as a voltage source with output resistance) and plotted the data. I used a range of both VA rating and secondary voltage. When I plotted Log(Zmodel) versus Log(VA) the data series were essentially linear. See below:
<snipped>
Note the axes are log-log. I then created a separate linear regression for each secondary voltage (lines on plot above). It turns out the the slopes of the regression lines are almost identical, and I decided on an "average" slope. It was then a process of adjusting the intercepts to make things line up by eye. When plotted against the secondary voltage, the intercepts fell on a nice line (more or less) as shown below:
<snipped>
These data regressions give me the ability to model the performance of ANY TRANSFORMER (based on the Antek data) having a VA between 50 and 1000 Watts and a secondary voltage between 12VAC and 60VAC. This pretty much covers the ranges used for audio power amplifiers.
I also wanted to be able to know the lumped transformer losses (core and copper losses) for an arbitrary transformer. It turns out that this is mostly just a function of the VA rating. Again, data taken from Antek's datasheets is plotted versus VA - the trend wasn't linear as higher VA transformers have slightly lower losses, so I used a quadratic relationship (see line in plot below):
<snipped>
So, what is this good for? Well, for instance, AndrewT's post above can be investigated using my spreadsheet:
I first go to the transformer model worksheet of my spreadsheet. I know I want a 35VAC secondary (all my models are based on a center tapped secondary) so I enter 35V for the secondary voltage. Let's say we use a 200W VA transformer, so enter 200 in the cell for VA. Leave the losses cell blank. Now go to the worksheet "music program material" to see the result. I will assume that Andrew meant 100W per channel into 4 ohms for a stereo amplifier playing music signals (not a full power square wave or other pathological input) and that the maximum ripple voltage on the caps should be no more than 2Vrms. The result is that a class-AB amplifier with a power supply using the specified transformer plus a pair of 43,000 uF caps will be able to output peak power of about 132 Watts per channel into 4 ohms. But as Gootee said, this thread is about the MINIMUM CAPACITANCE that can be used. So, let's say we want to know the minimum cap size that can still result in 100W of power output from the amp. Since cap size is influenced by ripple voltage in my calculations, just dial up the ripple voltage until you see 100W as the power output. The result is a rather anemic 10,336 uF resulting is a ripple voltage of 7.5 Vrms.
[Edit: I will follow up with more on this in the next post]
It's important to note that the required capacitance value will change with transformer VA as well as secondary voltage because the VA value influences the amount of "sag" or "stiffness" as current is drawn by the amplifier. This is why you can not just make claims about capacitance in your power supply without a good idea of how the transformer comes in to play. Hopefully this is not news to anyone.
I hope that the example above shows how my spreadsheet can be used to investigate various questions about the power supply, minimum required capacitance, ripple, etc. With the new addition of the data regressions for the Antek transformers, the user can quickly check the result for a hypothetical transformer of arbitrary VA and secondary voltage.
The only note of caution is that the Antek transformers are actually under rated by about 15% in terms of their VA rating compared to others. I have found this to be true when checking the calculations against some real world performance data that I measured.
GET THE UPDATED SPREADSHEET (VERSION 2.0) HERE:
Transformer_capability_calculations_VER2.0.xls
I HAVE REMOVED THE PREVIOUS VERSION.
-Charlie
Charlie,
I'm still catching up on reading posts (truly-excellent progress, Charlie!) but I thought that I had better mention...
This thread actually isn't about the MINIMUM capacitance that can be used. It's actually about "How much capacitance should be used?" and also "Is there a simple 'rule of thumb', such as 'always use X uF per RMS amp of output', that we can develop?". (I believe that there is no simple rule for determining the capacitance, unless we add so many constraints that the rule would then be almost useless.)
I mentioned finding the minimum capacitance because back when we started it seemed like a logical first step for trying to converge on the capacitance that COULD be used, on the way to trying to narrow it down to what capacitance SHOULD be used. Anyway, that effort got a LOT more involved than I anticipated, and I am still not quite finished with just that part.
ALSO, Onaudio (Harrison) is still waiting VERY patiently for a similar effort to be applied to selecting the decoupling capacitors! <grin> That should be even more interesting than this is!
All,
Last night I did multiple simulations where I swept the VA ratings, and observed the large effects (which we already knew about) that I need to try to account for, in my spreadsheet. But since I have the "per-unitized" scalable transformer model equations, I should already have the answer and just need to throw it all into the spreadsheet.
I also started to look at differences between my worst-case type of analysis (square wave signal, which finds cases where clipping will occur, with sine signals, that cannot be found with sine-only peak or average-level types of calculations) and the usual standard sine-signal type of calculations, and believe I might have identified at least one case where I might have mixed the two, in the equations I derived for the spreadsheet. So I'm going to re-do the derivation, BOTH ways, and will probably include both results, somehow, maybe by providing one set of numbers that "will work almost all the time" (i.e. a somewhat-lower "soft minimum" capacitance value, for example) but also providing what my original intent had evolved into, which will be somewhat-larger absolute "hard minimum" capacitance values and absolute-maximum RMS output power ratings such that even a millivolt of clipping "CANNOT" occur, with a square wave input at either 0 or 180 degrees phase angle, which covers all combinations of possible signal peak positions/phase angles vs time, relative to all possible charging pulse peak timing, including when low frequencies make the capacitors "hold their breath" through multiple recharging opportunities. Maybe later I can allow for a "minimum signal frequency" input. For now I'll either stay with the 25 Hz square wave repetition rate or go slightly lower.
Tom
i have seen the traffo for the st120 it uses a regulated B+ using a single ac secondary winding.....
I used monobloc setting with the ripple zeroed.Hey Daniel,
The power that can be delivered by a class AB amplifier connected to this (typical unregulated) power supply will be displayed in the green boxes, along with the capacitance per rail that is needed to achieve the ripple voltage you input above. To change the capacitance, change the ripple voltage.
You can investigate lots of scenarios this way... and since your interest in "low ripple" will be contrary to others interest in "minimum capacitance", each user should choose what suits them, or can investigate how the parts they have lying around will perform. I'm currently working up an "info and instructions" page that should be helpful.
-Charlie
Output drop voltage is at 3v, db crest is at 15.
Speaker load set to 8 ohms, and mains at 60hz.
I wish there was a supply capacitance readout.
The "vct" is for EI core center tap transformers.
Code:
9.1W 6,800u 1.1a25vct 28.6VA 12.5+12.5vac
15.0W 8,200u 1.5a30vct 44.7VA 15+15vac
25.0W 10,000u 2.0a36vct 71.3VA 18+18vac
30.0W 15,000u 1.9a40vct 77.9VA 20+20vac
38.0W 20,000u 2.2a44vct 97.5VA 22+22vac
55.0W 18,000u 2.7a50vct 135.7VA 25+25vac
65.0W 20,000u 2.8a56vct 158.5VA 28+28vac
98.0W 20,000u 3.7a64vct 234.9VA 32+32vac
Due to transformer prices, I opted for the low ripple selections of watts, capacitance and va from Tom's spreadsheet (that I may have misread), then matched up the figures to your spreadsheet, and deleting all mismatches to make the short list. On first glance, this seems to have worked.
But, could you double-check it for me?
72vac? Okay. 430VA apiece. Suited for a tube amp.I purchased two ST-120 transformers, they put out about 72 volts each. Does anyone know what VA these two oldies carry? IF a mono block was built what would be a est. of watts into 8 and 4 ohms? What size caps would be recommend for the two rails?
Need MosFet rail splitter if used for solid state amp.
After rail split there's about 52+52vdc rails, and 6a.
Capacitance minimum, 6800u//6800u caps, per rail.
Such high voltage then 6a is not suited for 4 ohms.
For 8 ohms you get about 120 Watt monobloc amp.
Why is the capacitor C16 in the schematic rated at 1000V ?
why not?
why not?
I was wondering if it was for any specific safety reason.
probably that was what they had plenty of at the time of production, and they got those very cheap........
Would that mean only 3 amps per transformer? I would think that a 8 pound transformer could put out more than 3 amps but I do not know. 120 watts was what was coming out of the amp to start with at 60 watts a channel.
We all listen to sinewaves. Even when simulated squarewaves and sawtooth waves are inserted into digitally created music, these are composed of sinewaves.I am curious...... nobody listens to sine waves....
Code:9.1W 6,800u 1.1a25vct 28.6VA 12.5+12.5vac 15.0W 8,200u 1.5a30vct 44.7VA 15+15vac 25.0W 10,000u 2.0a36vct 71.3VA 18+18vac 30.0W 15,000u 1.9a40vct 77.9VA 20+20vac 38.0W 20,000u 2.2a44vct 97.5VA 22+22vac 55.0W 18,000u 2.7a50vct 135.7VA 25+25vac 65.0W 20,000u 2.8a56vct 158.5VA 28+28vac 98.0W 20,000u 3.7a64vct 234.9VA 32+32vac
[...this paragraph moved below...]
Hi Daniel,
Looks good. To start, a couple of comments:
A. You can't "zero out the ripple" in my spreadsheet. Zero ripple could only be achieved with infinite capacitance...
B. Tom's output power in Watts figures seem to be slightly higher than what I calculate (See below) in most cases, but his figures and mine are in pretty good agreement.
I've copied your table from above, and done the following:
1. I used the capacitance specified in your table. To do this I varied the ripple voltage in my spreadsheet until the capacitance was a close match. There is a new column "Vripple" listing the corresponding ripple voltage.
2. I updated the output power column to reflect the values that my spreadsheet predicts for output power given the transformer listed and the capacitor size (per rail).
Here is the result:
Code:
output cap per ripple secondary AC
power rail voltage transformer info voltage
8 W 6,800u 0.73V 1.1a25vct 28.6VA 12.5+12.5vac
13 W 8,200u 0.76V 1.5a30vct 44.7VA 15+15vac
22 W 10,000u 0.78V 2.0a36vct 71.3VA 18+18vac
29 W 15,000u 0.59V 1.9a40vct 77.9VA 20+20vac
37 W 20,000u 0.50V 2.2a44vct 97.5VA 22+22vac
50 W 18,000u 0.64V 2.7a50vct 135.7VA 25+25vac
65 W 20,000u 0.65V 2.8a56vct 158.5VA 28+28vac
90 W 20,000u 0.76V 3.7a64vct 234.9VA 32+32vac[/FONT]
I'm not sure what you mean by the above statement. I believe that the output power is limited by the rail voltage for these cases, so the transformer VA is not going to play much of a role in output power. Reducing the capacitance will reduce the available output power, and increasing the capacitance might slightly increase power, but it depends on several things. You would have to run many scenarios... rather than making a huge table or tables, you can just run the numbers in my spreadsheet anytime and change any one of the variables to see the effect on the output power.Later, it would be interesting to make triplicate listings for each "watts" figure, for twice and for half the capacitance, to see how, per same ripple, the transformer va figure may change. . . and with the huge bonus that everyone could read it clearly.
-Charlie
- Power Supplies
- Power Supply Resevoir Size
