I've searched and searched but, I can't seem to find basic equations on how to design, what should be, a relatively simple power supply. I either get too many "unecessary" equations or I read "how to's" with missing parts.![scratch :scratch: :scratch:](https://files.diyaudio.com/forums/images/smilies/scratch1.gif)
I've tried using PSUII but can seem to get the voltages I need.
What I'm hoping you all could help me with are the equations to get two voltages, 250v & 180v
I have a 300-0-300 hammond transformer and was thinking of going with a full wave rectified circuit (solidstate) and for cost purposes a RC circuit.
I guess my real question is how do you calulate those different "branch" voltages I see in so many PS circuits?
I not looking for perfection more like, if they had a "tube power supply desing for dummies" i'd probably buy it.
The boozhound lab had one that was reeeally simple but it used a tube rectifier and a 275v x-former.
Many Thanks!
-Brett
Many Thanks!
-Brett
Brett,
I'd definitely recommend to gave another go at PSUD2 since it is the easiest and most accurate way to calculate almost any psu.
Just take your time to play around...it ain't that difficult!
With the numbers you mentioned it should be pretty easy to come up with a suitable design...
Good luck,
Oliver
Good luck,
Oliver
Brett,
To design the PSU you'll have to know what the load current is, and the DC resistance on the 300V-0-300V.
Try this with PSUDII
Full wave rectifier 300V and 75ohm DC resistance
C1=2uf
L1=10H, 200ohm
C2=50uF
L2=10H, 200ohm
C3=50uF
R1=2.5k
This will give you a starting point to get 250V @ 100mA out of your power transformer.
To get 180V use a series resistor from the 250V The resistor value (250-180)/Iload, Iload being the load on the 180V.
This type of PSU has a relative high internal resistance, this means the voltage will go up if load decreases. The main voltage-tuning element are C1 and L1.
Corne
C1=2uf
L1=10H, 200ohm
C2=50uF
L2=10H, 200ohm
C3=50uF
R1=2.5k
Corne
Defbrett said:Hi,
I not looking for perfection more like, if they had a "tube power supply desing for dummies" i'd probably buy it.![]()
Many Thanks!
-Brett
Brett,
You might be "penny wise and pound foolish". You are going to need high wattage in the dropping resistor(s), if you cap. I/P filter. That's an expense. Also, LOTS of waste heat will be generated. How do you propose to deal with the heat?
If you rectify the 300-0-300 with a 5AR4 and choke I/P filter, the rail voltage should come in CLOSE to the 250 V. you want. A critical current of approx. 25 mA. is needed, if the 1st inductor is 10 H. I'm guessing your signal tubes draw more than that. The slow starting 5AR4 allows you to forego a heat generating bleeder resistor across the 1st filter cap., if my guess is correct.
Ray moth, you're right that does help. I had it set for a second -I always figured that was a "long" time in electronics.
Corne, Thanks! that's a good starting point.
A few key terms I read here:
ILoad, does that equal the maxium load line current I selected? For instance for my 12AX7 i selected a 2ma/180v load line so, does that make ILoad(max) 2mA??
and for my EL84 I chose a 50mA/5K (x-former) loadline.
Then, to throw a curveball in there I wanted to make it a dual SE...ya i'm nuts.
If I had to, i'd just copy some other design as i've read Morgan Jones "Valve Amplifiers" and the "Tube amp book" over and over again but, this is a class project so I have to show/document most of my calculations. The amplifier seemed no problem, this power supply is driving me nuts though.
Appreciate all the help! You all are great!
I'll keep toying with PSUII and see what happens.
-Brett
-Brett
Brett,
The Iload for 180V is the DC current in the 12AX7 in your case 2mA. If there's a signal on the 12AX7 the current will vary but the average value remains 2mA. If the EL84 is SE and therefore class A the story is the same so Iload on 250V is 50mA. Because the 180V is made from the 180V the total current on the 250V is 54mA.
For a stereo amp the current must be 108mA
I missed you wanted to use RC filtering in your PSU.
So the PSUDII set-up is:
C1=50uF
R1=1100ohm
C2=50uf
R2=2314ohm (108mA @ 250V)
R1 dissipates 0.108*0.108*1100= 12.8Watts so you'll need at least a 15W resistor.
R2 simulates the required load.
The drop resistor to the 12AX7 power supply is (250-180)/(2*2mA)=17.5k.
You'll also need an extra 50uF capacitor for the 180V.
Corne
C1=50uF
R1=1100ohm
C2=50uf
Corne
thanks again!
So here is what I was able to come up with but, I'm going off the assumtion that the voltages i need will come from (C2) and (C3). Do I go by (C2) and (C3) voltages or the (L1) and (L2) voltages?
I attached a screen shot of my configuration.
Anyone know where I can get these chokes or can you recommend a place that will customer wind them??
It looks like so far this is what will work for me IF i'm reading the voltage correct from PSUD2
CLC LC
C1=2uf
L1=2H 800ohms
C2=50uf
15H 1K
C3=50uf
RL=2.5k
Or
CLC RC
C1=2uf
L1=2H 800ohms
C2=50uf
R1=900 ohms 1/2watt?
C3-50uf
RL=2.5k
CLC LC
C1=2uf
L1=2H 800ohms
C2=50uf
15H 1K
C3=50uf
RL=2.5k
Or
CLC RC
C1=2uf
L1=2H 800ohms
C2=50uf
C3-50uf
RL=2.5k
You won't find them anywhere and I don't see why you should; a much cheaper and more flexible method with better ripple suppression would be to use a 'regular' choke, say 10H / 200ohms (not critical) and put an additional RC network before the first B+. Playing with the value of the resistor allows you to dial in the right voltage. Playing with the input cap value does the same. You can split up the additional RC-network into dual mono for better channel separation if you're using a single power supply. For driver stage B+ just add one RC stage (or one for each leg of the stereo PS), no need for a choke there.
Simon
::update::
So i've since been able to design a power supply and i'm now just finishing up wiring it all together. So, I apply my load resistance turned on my PS and much to my dismay there is NO secondary voltage coming from the (brand new) Hammond x-former (372JX). I though at first it was my solid state relay but no, i decided to just take the mains line and connect it (through a fuse of course) directly to the x-former primaries.
According to Hammond its Blue/Black to 120v and Brown/White to 0v.
So after doing this I still don't get any secondary voltage!
(300-0-300)
What gives??? A DOA x-former?? Help!![bawling :bawling: :bawling:](https://files.diyaudio.com/forums/images/smilies/bawling.gif)
The Hammond 372JX also has a 5v winding and a 6.3v winding. Have you tried to see if there's any output from these? If so, it suggests the 300-0-300 secondary has a problem; if not, then the primary is suspect. Also, if there is a loud buzzing sound from the laminations, there may be a short-circuit somewhere.
No blown fuse, I still get 118V on my meter going to the primary of the x-former and there is no hum coming from it.
I'll check the other secondary taps and see if there's any voltage on those and i'll check for shorts, again.
thanks for the suggestions!
Is it fairly common for a transformer to be DOA? I mean, there aren't any moving parts and it's pot test at 2000V!!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It can happen. The thin wire used in the HV secondary is fragile and could've snapped if something went wrong in the winding process. By the same token, it can blow very quickly, too, if subjected to severe overload! A poor connection to the lead is also possible, I suppose.Is it fairly common for a transformer to be DOA? I mean, there aren't any moving parts and it's pot test at 2000V!!
The 2kv test is for insulation and it doesn't guarantee continuity of the windings.
The safest initial test you can make is to disconnect the tranny completely from the circuit and test for continuity of each winding using an ohm meter. The primary is probably around 10 ohm, the HV secondary is probably about 40 - 80 ohm in each half and the 5v and 6.3v secondaries will have very low resistance < 1 ohm.
Ok, here are the results:
Primaries:
Brown/White || Blue/Black = 1.4ohms
White/Black = 2.4ohms
White/Blue = infinite
Brown/Black = infinite
Brown/Blue = 2.5
Secondaries:
Red/RedYellow = 27ohms (in both cases)
Red/Red =50 ohms
Heater taps = .4ohms
Hammond recommends for 120v connection to the primaries:
Blue/Black=120v
Brown/White= 0V
This is a parallel connection i believe? but, anyways that's how i had them hooked up.
So, to me the primaries aren't near 10ohms but there IS resistance only i don't know what that means for me lol.
So what's next just connect some mains to the primaries and measure the output on the secondaries or, do I need to break out the credit card...![whazzat :whazzat: :whazzat:](https://files.diyaudio.com/forums/images/smilies/whazzat.gif)
On a side note, my ipod charger/touch switch relay power supply works sweeeeet. 5v for the ipod and 12v for the switch. It was acutally really close to those values and that one runs straight off mains.
Primaries:
Brown/Blue = 2.5
Secondaries:
Red/Red =50 ohms
Blue/Black=120v
Brown/White= 0V
From the readings, your transformer windings seem perfectly healthy. (I over-estimated the possible winding resistances but I was being pessimistic.)
Your idea of connecting up the primary to the mains and measuring the output of each secondary is probably your next step. Don't forget to check the voltage across the primary too - you never know, the wall socket, plug, power lead, etc. may be faulty! I agree that you need to connect the two separate primary windings in parallel for 120v, as described by Hammond and in your earlier post.
P.S. As always, please be very careful to avoid the risk of shock and other electrical hazards.
Hot-diggity-dam it works!!![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, I put it back in the PS and it works there also...so now the question remains..what caused it not to work..bad solder point perhaps?
I think it was either a bad solder or the crimp connector I used wasn't 'grabbing' the mains voltage..
thanks for the help! I'm going to put everything back together and test it once more and if it works, it's on to the amplifier.
Keep you posted...
thanks again!
-Brett
Keep you posted...
thanks again!
-Brett
Incidentally, if you have trouble designing a PSU again, you might like this:
http://www.valvewizard.co.uk
- Tubes / Valves
- Power Supply Design
