Misreading again?
Science works fine for me and powercords, mental pictures help too but are hardly what I'd call scientific.
Catch 22 ?
Cheers,![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Misreading again?
Science doesn't work for the power cord folks. "Mental pictures" do.
Catch 22 ?
Inductance Is One Parameter....
Any of you ever tried putting one of those ferrite sleeves on your power cords ? - I have and I heard strong differences.
Changing a PC from one with relatively low inductance to one of relatively high inductance ought to produce similar effect.
Eric.
Eric.
Re: Inductance Is One Parameter....
define "relatively low" and "relatively high" for us, please.
Otherwise, we may be talking about completely different things.
mrfeedback said:Changing a PC from one with relatively low inductance to one of relatively high inductance ought to produce similar effect.
Eric.
mrfeedback said:With respect to each other.
Eric.
Even an ex-President wouldn't have come up with such a great answer,
so you claim to be able to hear cords with 0.00000001mohm and cords with 0.00000000011mohm?
That is Godly hearing you got there.
Re: Get Your Terminology Correct, Sonny...........
I was talking about "relative" effects: inductances relative to ohms.
So if you want, the same question can be posted in henries: can you hear a cord with 0.0000000000000000000000000000000000000000000001mh from one with 0.00000000000000000000000000000000000000000000000000000000000000000011mh, which is relatively low (vis-a-vis the first one)?
mrfeedback said:In my theory books, inductance is expressed in Henries and not Ohms.
I am thinking that you have not read any such books, and much less tried the ferrite sleeves that I mentioned.
Eric.
Re: Re: Get Your Terminology Correct, Sonny...........
Why didn't you use H instead of mH? That would have given
an even more impressive sequence of zeroes.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Millwood,
Trouble is I think that perhaps the numbers are closer to about 1uH with 0.5 ohm inductive reactance. This is for about a 6' piece of 12AWG wire at 60hz. I'll admit I'm guessing. If you state gauge size, wire length, and test frequency, it should be easy to get a ball park figure. Tomorrow, I'll have access to an RCL meter and can measure. I just think you've got way too many zeros.
Regardless, what's the point?
JF
JF
Re: Re: Re: Get Your Terminology Correct, Sonny...........
if you insist,
It doesn't matter to me if it is H or mh or whatever, as long as Mr. Feedback can hear them,![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
trying to figure out how "relatively" accurate is Mr. Feedback's hearing is.
If you have real life examples between two power cords, it would be helpful to see at what frequencies the cable parameters can possibly come into play.
Looking forward to seeing your measurements.
Christer said:Why didn't you use H instead of mH? That would have given
an even more impressive sequence of zeroes.![]()
if you insist,
johnferrier said:Regardless, what's the point?
JF
Re: Re: Re: Re: Get Your Terminology Correct, Sonny...........
I was joking, of course. Since the way you wrote the numbers
is not the best way to make them easily comprehensible, as
you very well know, I took for granted you used that notation
just to emphasize how small the numbers were.
millwood said:
if you insist,.
Al I Am Saying Is That Effects Due To PC Reactance Are Possible........
Amplifier power input circuits are not purely resistive - IOW reactive and/or non-linear.
By definition a reactive line feeding such a power input circuit stores energy and this stored energy can set up electrical resonances, and these resonances would be influenced by the electrical values of the PC.
Different spectrums of primary resonances could get through to the secondary differently, and also cause different transformer to ground/chassis leakage currents.
Both of these are noise sources that could effect sonics - simple as that.
Sure, debatable is the audibility of this noise and products, but it is entirely possible that they are audible according to the amplifier/circuit design.
Eric.
millwood said:.....trying to figure out how "relatively" accurate is Mr. Feedback's hearing is.
Eric.
mrfeedback said:So why then do snubbers cause sonic changes Mark ?.
Eric.
for the same reason that neutrinos cause sonic change, Eric.
It seems some people never heard about noise suppression, xformer tank resonance and snubber networks?
Maybe someone should draw an equivalent circuit for those folk?
- power cord break-in or burn-in is there such a thing?
