Yes, golden ear people who fiddle with power cords probably overlook the simple common sense things in audio. They kind of remind me of those kids who run around in Hondas thinking they're sports cars, fiddling with exhausts, intakes, cams and manifolds. Yet they get outrun by beat up 5.0 Mustangs on a daily basis.
Solid Snake said:fiddling with exhausts, intakes, cams and manifolds.
well, at least exhausts, intakes, cams and manifolds do make cars go faster (or slower if not done appropriately). That is kind of upgrading to a BG cap, or Vishay resistor, etc.
The golden ear equivalents in the Honda world are those who put go-fast stickers on their cars, thinking (hoping?) for a miracle.
I'm stunned. Are you actually suggesting that upgrading to Vishays and BG makes amps sound different (better or worse)?
Peter Daniel said:Are you suggesting that using Vishays and BG makes amps sound different?
yes, you heard me right. Using BG and Vishays makes amps sound different, as does the use of egyptian maple wood casing and 100% purity gold plated directional cables.
So the forum had a positive influence on your listening education after all. I remember that when you started here, you didn't accept any suggestion that using different parts (especially resistors) might affect the sound.
THERE'S HOPE...JUST NOT MUCH.
Contrary to you and me, I have a nagging feeling he's using this in his system:
Peter Daniel said:So the forum had a positive influence on your listening education after all.
I am a born-again cable believer, . Thanks to Frank's talk on power cords.
It is an influence. Whether it is positive or negative we shall see.
Peter Daniel said:I remember that when you started here, you didn't accept any suggestion that using different parts (especially resistors) might affect the sound.
then you need to re-read what I had wrote. I am all for parts affecting sound. I wasn't sure and still aren't sure if any of our golden ears can hear the diffience.
What should matter to you is what you can hear as an individual.
If or not we believe we hear differences shouldn't matter to you one bit.
If nobody can hear a difference, especially so called golden ears, why use parts to affect the sound? It's a contradiction and waste of money.
that's precisely what I am trying to figure out. You were one step ahead of me,
But you have to ask those golden ears that question.
In short, you've been misread once more?
Too bad I know nobody with golden ears.
On powercords I go back to the basics....
A house has a 1/4 plus mile of #12 or #14 Romex, and those $500 power cords are plugged into a .50 cent duplex outlet. Seasoning a powercord can't help much, but an undersized cord does hurt performance.
The last 3 feet of the AC value chain can't make up for all the other possible deficits.
Run a dedicated 20 or 30 amp circuit with an upgraded outlet. I've also run quality line conditioners, but not sure to what actual sonic benefit.
Just my $.02,
-David
Just my $.02,
-David
No, it can't. And that's already assuming there are deficiencies...
However, in a typical setup PCs are rather in close proximity of ICs and LS cables.
So, there's a chance of one radiating into the other and into ICs and LS cables...
With a purposely designed PC you can also shield and filter out some RF and EM interference, no?
I expect king Midas had golden ears. To bad he isn't around
anymore.
One thing I have been thinking about is, assuming PCs can
make a difference, could it be that some of them have a
filtering effect that reduces inter-equipment coupling thróugh
the PCs if they are all plugged into the same wall outlet? I
could imagina a slight possibility that a CDP could couple a lot
of HF trash into the preamp this way, for instance.
This theory
would at least void the argument that the cables up to the
wall outlet are crappy.
You're getting warmer by the minute...
Filtering works in a bidirectional way in this case.
The same arguement holds for LS speakers being prone to RF injection and EMI from close proximity of unshielded PCs for instance.
A simple twisted pair or star quad goes along way into the right direction IMHO.
More importantly to the penny pinchers amongst us, it doesn't cost more than a tenner to find it out for yourselves.
Re: Re: re Speaker Wire Secret
Eric.
I was referring to the temperature dependence of the Manganin wire.EE_Mark said:What does "less than anything" sound like. Yes, since we've all been joking about how a power cord changes sound (good one!) I'd thought I'd throw in the manganin wire. It's about 10 ohms per foot. I recommend at least a mile of it for best sound.
Eric.
a free piece of Chinese wisdom: "you cannot see the forest because you are in the forest".
dw8083 said:On powercords I go back to the basics....
-David
absolutely the wrong approach. Science doesn't work for the power cord folks. "Mental pictures" do.
- power cord break-in or burn-in is there such a thing?
