I'm noob, but I would try a 22pf from base of T2 to base of T5, this is easy to try, don't have to change anything on board.
If prob on output, did you use resistor values on driver bases shown on drawing, maybe increase to 150R, also same for gate resistors on outputs.
Anyway that's what I would play with at first, remembering I'm only experimenter, not expert
use Quasi ACRTK schematic this circuit have perfect square wave.
I ave already made 2 pcb for NMOS....
Nmos sound is not so good like many Class AB Designs, I made Nmos before and have changed to Class D, never want go back to Class AB.
I tink so...
Class D is big improvement in Sound with low heat compare to class AB
Maybe in the future.... in this time my amp MUST work well!
The amp can not work well because you need about + 10 V / bootstrap to drive negative rail for full rail swing / perefct sine wave without oscillation. Thats why quasi make Acrtk Nmos Amp. This amp have + 10 V to fix this problem, check the schematic you will see
Class D work same, using 2 N Channel Mosfets and have +12 V Bias / Bootstrap for drive negative Mosfets
- Power amp under development
