Pfm 1047 ( big brother revisited )
Hi There,
here is my very last realization :
2 X 3 watts
Ultimate quality output transformers
Only two resistors and no capacitors in the signal path.
Separated batteries power supply.
Amazing simplicity
Transfixing musicality
Gorgeous on Fostex TWEETERS
Rock
Hi There,
2 X 3 watts
Amazing simplicity
Rock
Banned
Joined 2002
Hi There,
2 X 3 watts
Amazing simplicity
Rock
More information
everything is on the pics'
On your home site you mention your designs as protos
I take it we are looking at a planned commercial product ?
Hi There,
2 X 3 watts
Amazing simplicity
Rock
A very intriguing design. I guess the transformer provides the gain and the MOSFETs (?) buffer the signal. I have seen a schematic of something like this before. The quality of those transformers will be absolutely critical to the sound of the amplifier, which ones did you use? Is this amplifier only suitable for tweeters? I guess the output impedance is too high for many bass applications.
I suppose your batteries connect with the IEC inlet, be careful who connects this amplifier up or it could be catastrophic!
Pfm 1047
Dear Sir,
this amp is fitted with bipolar tansistor ( 2SD1047 ). It don't use any
Mosfet ! Output transformers are from ACEA ( a french company
specialiazed in audio transformers ).
And YES he can drive loudspeakers ( sensitivity at least 96 db 1W 1m ).
Amazing
Rock
Dear Sir,
Amazing
Rock
Rockmandrake
Your creations are so beautyfull, it makes me wanna quit doing electronics, since I will never reach this level.
However - I think your standard is dropping if you compare with your previous work.
I found that the insulating pad is not straight ( see picture)
Banned
Joined 2002
you're absolutely right
Would you care to post product numbers ie the transformers ? so others can build one ? That is very VERY sexy work, GREAT JOB!
Banned
Joined 2002
Pfm 1047
acea-fr - Présentation
chairman : Mr Pierre Cazaudarré
output transformer main specifications :
Ei 56 mm
Z = 7 ohm
secondaries = 4 & 8 ohm or others values
power = 5w
Rock
Ei 56 mm
Z = 7 ohm
power = 5w
Rock
Banned
Joined 2002
..What?
You don't like it?
Needs rats nest removed from inside
hehe - but that's what is making the music comming out.
It reminds me a bit of the old Kudelski Nagra... it's different... but well done
http://archive.liveauctioneers.com/archive3/nyshowplace/12546/0031_3_lg.jpg
- Post your Solid State pics here
