Polar measurements with automatic turntable
Some years ago Wim published his turntable project in this forum (DIY Automated rotary table for automatic polar measurements - diyAudio).
We picked up Wim’s design goals
1) make a complete polar measurement with 1 mouse click
2) table must be strong enough to carry heavy speakers (min 50kg)
3) it must be DIY
and added some more
4) should be able to communicate with ARTA (to realize 1))
5) easy to build, even for people without electronic skills
Thanks Wim (PIC Software), Dougie (USB Controller) and last but not least Ivo (additional ARTA turntable feature with data export) the turntable project is now finished.
The turntable has passed the first test in the lab with good results (fig 1: turntable with heavy load (60Kg))
A 360° measurement with 5° resolution will last roundabout 300 seconds (inclusive export of frd-files). The accuracy and the reproducibility are sufficient. Deviation from target angle is < +/- 0.5 degrees (fig 2: reproducibility).
The concept of the turntable is very simple
(fig 3: turntable, drawing).
What is needed:
The total cost of the turntable is about 250 USD.
Some more details could be found in the following papers (sorry, at the moment just in german language).
Kind Regards
Heinrich
  • AP-ARTA-AutomaticTurntable-GerRev1.3.pdf
  • ARTA-Hardware&Tools AutomaticTurntable-GerRev1.2.pdf
.. some additional pictures:
1) Turntable, small
2) ARTA turntable Menu
3) Turntable small + jig for horizontal measurement
4) Menu turntable, manual operation without ARTA
5) Menu, parameters for Operation
6) Turntable with heavy loudspeaker
7) Parts needed
More Information here: ARTA Turntable
Perfect tool in combination with VirtuixCAD: Software
Heinrich
This is a long shot - I'm developing my own rotating turntable for ARTA using an Arduino interface. I chose arduino because it can easily control stepper motors and other sensors needed for homing.
I was wondering if you could let me know how you got ARTA to talk to the turntable? I see that ARTA asks for an .exe for a program which drives the turntable, but how would I make a program which ARTA can use?
I am producing this turntable in the hopes that others find it useful. I am designing it to use off-the-shelf hardware, and the wooden components will be shared as 3D files enabling anyone to get them cut on a CNC.
Joined 2018
Is this the correct slewing ring?
Is it steel balls that I should be getting?
How about the type of holes?
Do you know of a supplier in North America who can provide such a ring or does it have to be ordered from Germany?
Interesting that this topic popped back up, since I might actually have an interest/use in doing something like this. It seems like it could be 'fairly straightforward' to adapt cheap 3d printer / cnc control boards and stepper motors to do something like this. The code to send gcode over usb should be possible to separate out from something like UGS.
I guess you have to evaluate the time needed to set something like this up vs the time to make the manual measurements the X times you'll actually need to do it.
Joined 2018
Joined 2018
