Hiya folks,
I've just picked up an old Playmaster 200 I'd like to refurbish. One channel works fine, the other sounds dead - but there was some warmup "rustle" on the other when turning the bass control, so I think both output channels are good. I haven't started troubleshooting yet, I had hoped it was the balance pot but that checks out OK, although a bit odd - it seems to be 2 linear 10k pots where the range works zeroR to centre then rising to 10k for last 1/2 turn - mirror image each side - presumably to keep crosstalk down. Don't fancy finding a replacement for that, will probably go with Left and Right volumes if it's an issue. BUT! Does anyone have a copy of the circuit diagram, or even the construction articles? I though it must be on the net somewhere, but a couple nights on google haven't found anything... cheers,
Terry
Terry
hehe, Mines dead on one channel on the preamp as well. I have a bypass of the preamp and I'm running it off the HTPC direct. I thought that if I didn't fix the preamp that it would give me motivation to work on my new one. Unfortunately not
I have the schematic somewhere, but I have moved house recently so finding it might be an issue.
I've actually modified mine. I bypassed the tone and balance controls completely, and also made some modifications to the last opamp stage (I think after the volume control) based on the revision to the design of the Playmaster 60/60. This improved stability as the preamp section was prone to oscillation.
I like the amp. Definitely worth fixing I'd say. Even if you just bypass the preamp and use it as a power amp
here is a thumbnail (the gallery is dead at the moment) of mine the first time one channel died. My 2yo poked a chopstick in through one of the holes where balance or tone pots used to be and broke a component leg off
Tony.
Tony.
Hmmm - thanks for the suggestion - that's not a bad idea at all. I think I'll pop in a set of pre-out/in sockets, that way I can feed it straight from the PC in my study while I think of my next move. I was hoping to move it to the workshop next door and run some big old Sansui's off it, but that can wait - I have a Sansui AU-D9 that has a dead output side that I'd like to fix for the study, then I can either sort the preamp in the Playmaster or just run it off the tape outputs of the Sansui... hmmm, way too many broken toys, way too little time
I posted the schematic for the power amp here --> http://www.diyaudio.com/forums/solid-state/19626-suggestions-improvement.html#post228803 about 12 years ago...
edit: I've also completed the B1 based preamp since the above post
Tony.
Tony.
Hello folks, new starter here.
I have a Playmaster Series 200 which I built in 1985 from a Jaycar kit. It worked straight away, but has had a few problems.
The first is that the Dubbing 1-2 light always comes on. It goes off when pressed and doesn't cause any other problems, so didn't bother to fix it, as it is probably related to a faulty IC on the sub-board, which would have to be unsoldered.
The major problem has been failure (twice) with extreme prejudice (BANG!!) of the mains power switch. Not hard to replace, but the trouble is that both times it took out Q20 (a BC327) involved in speaker switching relay activation - hence Local/Remote/Both/Off switch out of action. Replaced the puny switch on the second failure with a much meatier toggle switch, and routed the mains cables to the switch as far away as possible from circuitry, between the internal fins of the heat sink. No such failure since.
Another major problem has been failure of Aux left channel. This occurred after a loud blat!! on this channel, cause still unknown. Went around this area of the board re-soldering suspect dry joints, but no luck. Am now going to replace IC10 switching IC as the most likely candidate.
When re-soldering dry joints did notice an obvious dry joint at the central earthing point pin. Probably loose because the pin is vulnerable to tugging by the wire when disassembling the amp. This re-soldering fixed a faint background noise audible on occasions.
Also much trouble with the sub-board locating screw posts coming adrift from the bottom panel. Soldered these to the bottom, but not a good fix as they sometimes come loose.
This amp is now over 30 years old so I am wondering about replacing electro caps. Has anyone found a need to do this? It sounds just as good as it ever did, and there are no suspicious bulges or leaks, so I am reluctant to fix what ain't broke.
My overall impression of the amp is that it is great, and as good as I'll ever need for stereo work, but a remote volume control at least would be good.
The CMOS switching IC's are very sensitive to static, so could go if some static discharged on the input I guess (edit I know I have had to replace a few over the years). Not sure it would go with a blat though...
At 30+ years old I would not be surprised if some caps have failed, I re-capped mine at somewhere around the 16 year mark I think (except the main supply caps, which I purchased some time ago but have not yet replaced.
Mine was a Dick Smith kit. Not sure whether the Circuit board quality is better in the jaycar, but one thing to be very careful of if doing a re-cap is not lifting tracks on the board! I did mine with Panasonic FC's at the time for the electros, and I think I used evox pps for the greencap bypass caps, and replaced all of the ceramics with NPO types.
If you are happy with it and there are no obvious problems then it's probably safest just to leave it as is. There are a LOT of electro's on the board, and pulling the amp apart to get good access is not fun, you need to set aside some serious time if you are going to tackle it
Tony.
Tony.
Thanks for the tips and thoughts wintermute. Have ordered the IC to fix the aux left problem and will check all the voltages around the board (written on the board when first assembled) and if any have changed will consider looking at the electros. The amp had constant use for the first 5 years or so of its life and intermittent thereafter - so hopefully hasn't seen too much heat stress.
Re the blat!! The RCA connectors have always been rather tight, and I assumed at the time that the connections to the board had been strained to failure. If the earth was open circuit there might be loud buzz. Re-soldering all these joints (which looked OK) didn't fix the left channel - but might have caused the original failure if the IC proves to be u/s.
The Jaycar kit has a fibreglass board and I haven't encountered any track lift problems.
Disassembly to the point required for easy access means removing both top and bottom, back and front and unsoldering the main DC leads - not fun as you infer. Won't do this unless I have to that's for sure. If care is not taken reassembling, strain on the input and output panel soldered joints and volume, balance and tone control soldered joints can cause them to fail. For some reason the volume control was worse in this respect, so in the end I made the connections for it flexible.
The Dick Smith kit came out later than the Jaycar and had better presentation as I remember. The Jaycar kit has sockets for all of the ICs on the main board, but not for he sub board.
Other problem I had was failure of the volume control - noisy, not fixed by cleaning and lubrication. Couldn't get the multi detent original, had to make do with 10 detent, quarter of the original 40. Bass control also became noisy but cleaning and lubrication was a fix.
Also fitted a relay to prevent plops in the headphones.
Just been listening to Dire Straits, Money for nothing - still does the percussion soon after the start of this track beautifully through a pair of Richter predator Sabres. Has to be loud!!
Yes volume pots were my biggest problem. I bypassed the tone controls and balance pot years ago when pots started getting dodgy. I also changed the preamp section to add the components that were in the playmaster 60/60 which had a slightly revised version of the series 200 pre (without all the cmos switches) which improved stability.
My preamp is completely bypassed now (I never went back to find the fault on one channel) and a DC-B1 with my active crossover now feeds 270Hz and down to the series 200. an LM3886 handles the frequencies above 270Hz.
I prefer the sound of the mosfet amp to the LM3886 running full range, but this makes the most sense for a biamped setup.
I built mine in 1987, and it has been in pretty much constant service (except for about 1 year when I was using the LM3886 because there was something wrong with the preamp (again) and I didn't have time to fix it. It copped a lot of abuse at UNI parties and never missed a beat! I don't think you have to worry too much about heat stress!
It's funny you say the Dick Smith kit had better presentation, I wanted a jaycar one, but the DS one was on runout special and I got it for $399 (which was already a stretch for a uni student supporting himself), I think the ones at Jaycar were still selling for the original price which from memory was $599.
Tony.
Tony.
Must see if I still have EA for the time of the 60/60 and look at the changes made. If not too difficult might have a go. But my ears are 30 years older now so probably wouldn't notice the difference.
Re Dick Smith, the main thing I remember is that the main power switch was larger on the front panel and appeared to be illuminated. The other impression is that it looked better, but don't remember why now.
Yes it has a large illuminated power switch. I think it had bigger toggle switches for stereo/mono and mute as well. (mine are long gone as the switches broke and I couldn't get replacements).
The speaker connectors are woeful (not sure what the ones on the jaycar were like). It sounds like the heatsinks are different too, as mine are completly smooth on the inside, only fins on the outside.
I found with mine I would sometimes get oscillation when adjusting the tone controls, the mods from the 60/60 I think involved addition of a couple of film caps and possibly a resitsor, but this removed the tendency to oscillate. I've got the EA with the 60/60 somewhere if you can't find it (though I would have to as well)
Tony.
Tony.
The speaker terminals are of the type where the end of the wire is pushed into a hole, and the end secured by turning a plastic knob which clamps the cable with two sheet metal clamps. Have never been happy with the way these work, but that said they haven't given any trouble.
Have never had oscillation problems (unless the failure of the Aux left was due to oscillation).
I haven't been able to find a copy of the 60/60 article. Will keep looking. Have joined dropbox and have fiddled around for a half an hour but haven't figured out how to open the links given in a 60/60 thread.
Have looked at possibilities for remote volume control.
The first is a kit offered by Altronics:
http://www.altronics.com.au/p/k5026-remote-volume-control-kit/
Potential problems are the size of the controller, which looks as it might foul the right hand heatsink and possibly the forward right power transistor, and the value of the pot resistance which is not stated. Similar kits seen elsewhere state this to be 20/20k.
The size/fouling issue might be solved by turning the pot and its drive 90 degrees anticlockwise, though the knob would also be turned 90 deg putting it out of registration with the front panel graduations. The resistance issue would depend upon the circuitry between IC3 and IC4 being adaptable to 20/20k. I don’t understand enough about opamps to know if this is possible, but looking at the specs for TL071, the output voltage is not very sensitive to output resistance at higher resistances.
There are other motorised remote volume controls, but their issues are similar (eg remote 50k items - Get great deals on items on eBay Stores! or
http://stores.ebay.com.au/biwecity?_dmd=1&_nkw=remote+volume).
Another possibility would be to go digital given that forums indicate that volume pots are apt to fail, eg
LC75342 4 Source Input Remote Volume Preamplifier Board KIT | eBay
Problems here would seem to be patching the kit into the existing circuitry perhaps bypassing the channel selection option of the kit, or the preamp of the Playmaster. Hum might occur given the susceptibility of the Playmaster. Then there is the previous size issue.
Anyway, these are my thoughts so far.
Good pic of the Dick Smith version of the Series 200 amp. Went for $50. I would have liked the silver highlights on the knobs when I saw this kit years ago.
Playmaster Series 200 Mosfet Amplifier | eBay
I've thought about the remote volume pot before as well. The alps motorized pot was always the one I wanted but I think it was too big too. I think I have used 20K pots for volume without issues, but not 100% sure. there have been many in my amp over the years! The only one I have been happy with is the one in my B1 preamp, which is a $10 pseudo stepped attenuator from HK. Finally a vlume pot with accurate tracking of left and right channels!
I've thought a number of times that if you could add a gear to the pot shaft (or a pully) you could use a small motor and controller to turn whatever pot you want. a shaft extension may help getting things out of the way. I've added a pic of my b1/synergy active crossover with shaft extensions.
The one in the ebay pics looks almost 100% original. Only thing missing are the nicads. I forgot that my original power switch failed. I have an illuminated rocker switch now.
Tony.
Tony.
I like the idea of pulleys and or extension shafts. Maybe universal joints. Could then mount the volume control on a bracket up on the heat sink.
Tried changing 4053 to no avail with regard to left Aux fault. Must now bite the bullet and disassemble and look for dry joints or other faults before the 4053.
Will take the opportunity to put in an IEC 240V socket.
On thinking about the pulley solution it seems to me that the critical issue would be side loading on the pot shaft produced by belt tension. To minimize this, with the pot mounted up on the heat sink, a shaft mounted in bushes or bearings on the heat sink would be needed. This shaft would take the side loading. This could be implemented using printer hardware (toothed belts and pulleys). Gears might be better with regard to side force but alignment might be more difficult. The upshot is that a mechanical solution to remote volume control is not very elegant on the Series 200, at least with the motorized pots available now.
Yes the biggest problem with motorized pots in the series 200 is that they are bulky and generally because of the original PCB mounting of the pots, getting clearance is a problem. You mentioned universal joints which could possibly be another option but might be quite tricky to implement!
Tony.
Tony.
A progress report:
Re the left Aux fault - turned out that when I went around likely dry solder joints I created a short circuit with a fine sliver of solder. This removed, new 4052 could work, so left Aux working again. Just shows you that in fixing a problem another can be created.
Also put in 240V IEC socket - required hacking a bit off one internal heat sink fin..
Checked all voltages that I had measured originally, all good. Will reset the quiescent current next time I have it open. Only anomaly was scorched 6.8ohm 1W resistor in the output RLC network. Popped one end of this - it checks out OK, but will replace. Should I install a higher wattage resistor, or could it function as a fuse of last resort? I don't think that it is given that the 6.8Henry inductance is parallel.
Re the remote volume control - in pricing various bits to provide an indirect connection from the knob to the potentiometer, these parts more expensive than the cheaper kits having 50/50K pot. So decided to buy this first and patch it in and see if there are any noise or other unforeseen electronic problem.
The kit requires 12V/0.5amp power supply. I am not inclined draw this off the +15V supply through a regulator and am considering installing a dedicated rectifier and regulator, assuming that the transformer winding can handle the current. There is no spec on the transformer current handling capability in the original article, so thoughts on this appreciated.
Kit chosen here: 2 Channel Remote Motor Alps Volume Potentiometer Control Adjust 50kA LED Displa | eBay
Instructions in Chinglish in the listing , hard to follow. Also two captions labelled "Display panel control interface" which I didn't notice until ordering. Sent in questions but they provide no answer and are only worried about feedback. But can't expect much for $17.
Will provide a further report when the item arrives.
- Playmaster Series 200 Circuit
