placing the driver 1/3rd of the length down a TL
Fantastic. Thanks Scottmoose.
The other question is tuning- I read somewhere that you should tune the quarter wave length around 5 khz away from driver resonance..the prob is I can't remember if that is above or below the driver resonance! Mind you I doubt its easy to get it spot on anyway, too many factors involved..
.........or take the quite high qts into consideration?
I do. Good rule-of-thumb in today's T/S centric 'society':
Up to a ~0.707 Qts after any series resistance is accounted for: sim a T/S max flat alignment and make Fp whatever Fb it calcs.
Above this point, it's generally better to use Fp = Fs/Qts and definitely if it's a >1.0 Qts or you want the TL equivalent of a T/S max flat [AKA max flat impedance] alignment.
Works for me anyway. ;) Try it both ways plus ignoring Qts, calculate them using MJK's Classic Alignment Tables, sim them in his software and let us know what you think.
GM
Looks like some stylized '50s era Cadillac tail fin/light assembly. :up:
GM
:D:D....Is this a half-wave TL or an quarter-wave with the terminating opening
marked yellow in this picture copy?
..Will it work in theory? I'm worried about lobing..
I have no doubt that this wouldn't work but the lobing issue is another consideration to deal with:
I would at first hand add another smaller FR driver to cure this inevitable problem or place a small capacitor in parallel with the lower placed driver if and only if the drivers are hooked up in series.
b:)
b:)
Thanks Bjorno
No doubt it would or wouldnt work? would, I hope!:)
I thought about adding a tweet and or maybe a 3rd sealed driver enclosure and rolling the Hfs off the outside two.. but maybe its a bit overkill, looks wise.
I like the idea of rolling off the lower driver but don't I need an inductor?:confused: how does that work?
Hi Bill,
Sorry for being late...
It will work :D
Good idea.
Place a small capacitor in parallel with the lower placed driver if the drivers are hooked up in series but when using the drivers in parallel: You're right: An inductor would be the first to choose.
Example of capacitor use: The patented Logitec Fdd2 filter : See the submitted picture:D
b:)
b:)
Cheers dude! Tack sa mycket!
Ah, so Logitec figured out a way of not using an inductor and.. strictly speaking ..:D I could try this but not for commercial use.
I will probably go this route or I had an idea to put an omni type lens in front of one driver.:cool:
